Hydraulic chute build
7,231
awesome
L2502, BH77, K54-22-06B
Sep 16, 2018
320
215
ottawa
Ok, I just found some 3/8 on amazon. 37$ (27usd) for 2, shipping included. I won't need extra fittings.
Old_Paint
Dec 5, 2020
2,036
2,305
AL
You lost me with "3FV". I have a 2spool valve hooked up on my 3 hoses that the backhoe would use.
The sproket works when I rotate manually. Didnt weld it on the hub yet. I know it probably wont work well. So I'm gonna look around for shops that sell gears.
3rd Function Valve - See the letters in RED. I speak in acronyms as good as any military spec sheet. That's just a TLA (three letter acronym)
awesome
Sep 16, 2018
320
215
ottawa
I'm.gonna receive the restrictors on dec 16. I'm being impatient and tempted to try something else in the meantime. I saw some people tapping the inside of a fitting, adding a bolt and then drilling a small hole. Would it be a bad idea to just fill the inside of a fitting with a big ugly weld blob? I'm guessing that if aome particles would break free it could break something.
7,231
You can make a restrictor plate by drilling a .030 or .060 hole in a small metal disc then put the plate inside the fitting. I almost suggested that a while back.
Jsjac
B2650
Feb 13, 2022
245
402
The easiest way is like you said. Drill and tap for a pipe plug size and drill a very small hole to start.
Maybe a 1/16".
I have used this method for slowing functions on equipment we sell.
Weld might be hard to drill. Can also have small pieces possibly dislodge b
awesome
Sep 16, 2018
320
215
ottawa
I made a small disc with a 1/16 hole.
At low throttle it's manageable. At high throttle it's still too fast. The restrictors I ordered will be 1/32 so it should help. My intuition says that adding 2 restrictors instead of just 1 won't make a difference.
Now it doesn't make a difference whether I slap the valve full on or just barely. But that was expected and I understand why.
Donystoy
Dec 10, 2013
735
378
Binbrook, Ontario
You are doing a great job. My new blower has the identical chute rotator from the factory and even it rotates faster than I like so I might eventually install a restrictor in the lines as well. I might also say that mine does not rotate all the way and just stops where the teeth stop. Does not seem to cause any issues.
awesome
Sep 16, 2018
320
215
ottawa
I just received the 1/32 restrictor today.
This is much better. And it doesn't matter if I'm on high or low throttle.
NetMagi
BX25D (sold), L2501HST w/BH77 Backhoe
Dec 30, 2014
132
95
Pennsylvania
electric holding up very well for me so far ~3 seasons on it:
