Hey All,
I parked my M7060 at my hunting property a few months ago.
From Winter use the shuttle shift has seized. I'm attempting to remove the push pull cable, or at least unhook so I can manually put it in neutral to get the machine started.
Within the time it's sat a mouse got inside the cab and setup shop under the seat behind the metal cover.
At this point I can't get the machine to turn over. Shuttle shift needs to be in neutral correct?
There is a code on the display (Eng Ng).
I found the wire going to the fuel sending unit? On top of the tank had to have been chewed through since I parked it.
I stripped the 2 wires and have them temporarily connected back together.
The code still reads on the dash.
I checked the ECU & ecu backup fuses and they are good.
I'm stumped currently and need to get the tractor to my shop.
Please help. Thanks, Chris
