Hi all,
I've got an L35 that the previous owner hacked a bunch of wiring up on and I would like to return it back to factory (or close to it). Right now, I need to turn the key switch to the accessory position as normal, but then use an extra start button they have wired in to start the tractor. They also had a generic starter solenoid bolted the frame, but only two terminals are wired, so I'm not sure how it would actually work. Using the key to shut the engine off also doesn't work, I have to use the manual shut off.
I've been going through the wiring diagram and trying to compare it to what I have on the tractor, but some times a picture is worth 1000 words. I'm wondering if someone with an L35 might be able to snap a picture or two down by the starter? Just hoping to get some clues as to how I should put it back to factory.
This is what I'm currently working with
