Hi.
I havent been on here in a while as ive had no issues with my tractor. it was running well for the past year. i was using it and then shut it off to go and do something and when i came back it wont even attempt to turn over. the battery is only a few months old as the old one was leaking. i checked clutch saftey switch and have continuity. relay timer was tested and ok. i pulled the starter and took the back cover off the solenoid and cleaned all the contact areas ( ill have to get a solenoid rebuild kit as the 2 stud contacts and the plunger ring are pitted) i bench tested the starter and it tested out ok. what i dont understand is as soon as i put everything back in the tractor it wont turn the engine . i have 12.8 vdc at the starter post and when i apply the same voltage to the solenoid spade i get no response at all. If anyone has any insight it would be greatly appreciated.
thanks
thanks
