So... thanks for all the advice!
Here's what I'm thinking I want to do now:
loader
3rd function
6-way diverter with (manual) toggle switch/lever to route the 3 loader functions to the back for 3 additional rear remotes
3 Kubota OEM float valves (maybe one should be a detent instead)
power beyond toggle port for the log splitter. (should be the kit for the backhoe?)
That way I can control the offset ditch bank flail mower with the loader joystick, assuming the loader dump and float are not goofy to use. Might need a flow restrictor somewhere if the flail moves too fast.
I also decided to up my budget to get a HST4760 or HST6060 instead... Can those handle more than 3 ports stacked up in the back or will I need to get something fabricated to mount things? (e.g. can more be mounted with longer bolt rods and mounting ports both above and below the support post on those tractors).
Is this a reasonable setup?
I'm also talking to the next two closest dealers and they at least knew what I was talking about when I asked about remotes. My local dealer is now saying that they will only put OEM parts on. (which figures as they mentioned that they lost their hydraulics guy...)
loader
3rd function
