TheMurf
BX1880.with loader and 48 inch deck. 1990 Gravel 12G Riding tractor.
What Spray lubricant do you Gentlemen recommended for using in the linkages and lube points in a BX tractor ? Is chain lube ok ? Or, white litho grease,ok ? I'm surprised there are not more zerk fittings on these machines. Such as the tie rods, steering gear, shift linkage, etc. My old Gravely has fifteen zerk fittings for grease..
