Temp storage building
William1
BX25D
Jul 28, 2015
1,275
465
Richmond, Virginia
I had one up for over seven years, setup in the woods. a few small pine tree branches pierced it. Duct taped them up. Some wear at the framing, not significant. Had some pretty heavy snow loads on it, skewed the frame slightly. Certainly worth the $160 from HF.
Bought a new shelter this year from HF ($200). I also bought a replacement/spare shell ($70)
A lot easier than tarping it up at the end of the day.
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,128
3,388
this could work. The bars that hold the canvas down on the sides are adjustable and can be moved up or down to adjust the tension on the cover. I could probably loosen them and get some pipe insulation in there.
Hopefully that works out for ya! The pipe insulation would hold up longer (I believe) than the noodles. We use that tactic for our EZ Ups at the track. It increases tension enough to prevent water from pooling.
JeremyBX2200
BX2200
Aug 3, 2020
506
455
Indiana
Got this done for the most part.
Lag bolted the middle legs down and then used metal strapping on the end ones since they don’t have holes for lags.
Put gravel on the inside for a floor. May end up adding more depending on how it lasts. It will be nice to be able to move things out of the detached garage and finally get my workshop back.
BigG
Sep 14, 2018
1,951
774
West Central,FL
Add at least a second strap make it longer and and more screws. Do not ask me why I know to do this
