nbryan
Good points all, BUT:As for speed ranges, L is for Loader, M is for mowing, 3 point work or brush hogging and H is for traveling (Highway).
The M for 3-point attachment work and bush hogging in my case usually means dropping down to L for many operations. Especially if the 3-point is dragging any ground engaging implements like a sub-soiler or plow. Or I'm working with the box scraper moving soil and gravel around.
And very often if the loader is hauling any distances then I'll travel loaded in M on even terrain. With the loaded FEL dropped as low as safelty drivable.
The L,M ranges are often switched between in my case for those reasons.
And the 4WD lever is switched on and off regularly too. With it on for heavy front load traction enhancement, any turning on soft growith the load, und will chew the ground up a bit every turn. So I'll often use the 4WD while loading up then drop to 2WD to travel and turn on level ground as long as the back wheels have good traction.
