My RTV has an electrical issue somewhere and I'm not sure what's causing it. I first noticed inconsistent starting, where the starter would engage but struggle to turn the flywheel, but then the next two or three starts would be crisp and perfect. I ruled out the battery (it load tested fine at O'Rileys, but put on a new one anyway which registered 14v while the RTV was running). Then I noticed that if I was touching the roll bar while I switched off the key, I would get shocked. Then, occasionally, I would get shocked if I touched the metal roll bar while it was running. And now the starter is completely dead. Turning the key makes no sound for several seconds before I can hear the flywheel try to turn with a tiny grunt, then nothing. The fuel pump still primes with the key half-turned, and the battery is still registering fine. I had to tow the RTV back to the house because it died on the trail (of course) and ordered a new starter.
Any ideas for the shocking? I'm assuming something is grounding out on the frame, which might have contributed to the starter problems, I'm just not sure where to start. I would say the ignition switch, but there are so many other wires on this thing I'm feeling a little overwhelmed. In any case, I can't test or find it until I get the starter out and replaced.
I also replied to an older thread about replacing the starter, because I can't get the damn flywheel off to remove the two screws for the starter... If anyone has tips or tricks https://www.orangetractortalks.com/forums/threads/400-rtv-starter.54601/#post-586424
