PTO Gear lever will not move
DWTrisler
L2501
Oct 18, 2022
11
Tennessee
I have a L2501 gear driven. I am troubleshooting a no start issue. Noticed that the PTO lever is impossible to move. it is currently disengaged. Thoughts?
6,323
random thoughts...
Hmm.. disengaged... means it SHOULD be able to start, NOT a 'PTO engaged' problem......
Is the lever mechanically connect to tranny or cable connected ?
Wonder if you hand rotate the PTO shaft if the PTO does disengage, releasing the 'lever'
Roadworthy
L2501 HST
Aug 17, 2019
1,647
530
Benton City, WA
Does the starter crank the engine over? If it does, all your safeties are satisfied. If it does not you probably have an issue with a safety interlock. If that model has an OPC or operator presence control that would do it, too. My L2501 is HST. I have had issues with the seat safety. My PTO lever is on the fender and operates a cable, it's not a direct shift. I do have to depress the clutch to engage it or start the tractor.
Nicksacco
Sep 15, 2021
770
504
Bahama, NC
I found this (it is for HST however - does this shed any light?)
OR THIS
Mak65
L2501 HST
Apr 25, 2019
152
118
TX
i have an HST L2501. This issue is common though never had the lever stick but the cable in the housing. Get some lubricant with a nozzle “straw”. Put the straw where the cable goes into the shielding. And spray liberally. Go to opposite end and spray up that end too (not easy to access). Let it set then work the lever.
Fordtech86
L3200
Aug 7, 2018
4,966
5,919
Pineville,LA
Gear models don’t have a cable operated pto…
spin the pto shaft and retry to engage the pto…
tlefire
B7100, L2350, L2501
May 18, 2017
103
talladega alabama
If its not turning over, put the transmission in neutral and shift selector in neutral and see if it will turn over or start. This bypasses all the safety switches except the pto.
Fordtech86
L3200
Aug 7, 2018
4,966
5,919
Pineville,LA
It only needs the range lever (High,low,reverse lever) in neutral and pto disengaged to crank…
Mak65
L2501 HST
Apr 25, 2019
152
118
TX
Oops! I read OP’s and then someone mentioned HST and I got off track. Sorry.
