B26TLB not working in 2wd
timefarmer
B26tlb
Oct 16, 2022
14
Ok gents need some advise from the wise.
4wd works but back tires seemingly no power unless i use diff lock
Engage 2wd nothing unless i use diff lock
Tried left right brake with 2wd engaged. Hit right brake it goes forward hit left brake nothing. So it seems to me no right rear wheel power. Is this correct? Any other diagnosis i need to perform?
And what/how do i fix this?
timefarmer
B26tlb
Oct 16, 2022
14
broken axle or broken diff. Probably axle. Gonna have to pull it apart to find out.
Ok thats what i figured. Im sure pulling it apart is not easy as axle is behind frame on b26.
Can anyone post the rear axle section of the b26 workshop manual for me? I cant find the workshop manual online so a full document would be much appreciated!
timefarmer
B26tlb
Oct 16, 2022
14
Also another symptom i noticed.. in a super tight turn with 4wd on i hear a metal thunk sound from back right axle area
5,066
This just might be the time to buy yourself a copy of the workshop manual!
timefarmer
B26tlb
Oct 16, 2022
14
Personally a pdf copy would be better anyways as i can store it online and not lose it due to water fire grease etc... do they have a pdf available anywhere i have not been able to find one for sale or download from a legit looking source
5,066
Yea dealership wanted 80 bucks for one... me over here wondering why kubota doesnt just post pdf free. Not exactly stacked in cash around here :(
$80 from your dealer is apparently a very good deal.
Cheapest USED one on E-Bay is $122.
New one on E-Bay is $199.
Though I don't need it often, (because Kubotas are reliable) I would not want to be muddling through a major repair on my Kubota L48 TLB without a WSM.
Access to one page or one paragraph, could prevent a costly mistake!
#40Fan
291
166
From the looks of the .pdf file, if the axle was broken (snapped in two), it would have pulled itself out of the housing since it is only retained by the Cir-clip. Axle could still be damaged where the larger gear slips onto it. Could be the gear as well.
Looks like a fun job!
timefarmer
B26tlb
Oct 16, 2022
14
Thanks any other tests or diags i could do to get more info before taking apart?
2,814
1,531
Are you taking a poll or working up the nerve to start? LOL
You're going to find the answer when you pull that axle case off. Be careful.
You can use the stabilizers to raise it up to get the tire and wheel off. Block it up. Drain the fluid, including plugs at the bull gear cases, assuming it has them. Then remove whatever's in the way and unbolt the case. Be careful, that stuff's heavy.
timefarmer
B26tlb
Oct 16, 2022
14
Just gathering info gonna be a few days before i have a space ready to pull it apart
