Does this tractor usually run hot? I've been working it pretty hard and have to clean the radiator and screen even the air filter after ever use from grass. Takes about 40-60min for it took get all the way up to H on the temp monitor. When it does i take off all the load from the engine. Is it better to just park it when it's hot or let it idle?
It was reading hot when i tuned off the engine i could hear radiator gurgling sounds. I will check the radiator level once it cools down.
