Clutch needed to change gear range with a HST?
Jayhawk238
2004 L5030 HST/CAB
Oct 30, 2010
97
10
Featherville, ID, United States
I noticed that the clutch is not needed to go to high, mid or low range on my HST. Is this normal or do I have a problem? There was/is no grinding of gears or any kind of noise or resistance. The tractor was running at about 2000 rpm at the time.
NoJacketRequired
May 25, 2016
432
68
Ottawa, Ontario
Just make sure the HST pedal is in the neutral position before shifting range - the transmission must be fully unloaded for the range change to happen.
4,901
With any 'tranny' that has straight cut gears, you need to stop them spinning before you change gears, to prevent that grrrrinding gear damage we've all heard before.
Trannies with 'synchros' in them are easier to shift and of course if you get the 'timing and speed' just right, no need for a clutch with any tranny......
jkrubi12
B2601/LA435/QA54"/BH70/B8160box/BB1254/PFL1242/SGC0554/WC-68 Chipper
Sep 24, 2012
397
289
right coast
What about changing from 2WD to 4WD? I used to change while 'rolling' (gears 'unloaded') but the manual says the tractor must be stopped. Never had a problem, but don't want one either, so now I come to a stop before changing from 2WD to 4WD & back.
IMO the 2WD to 4WD shift & back, while gears are unloaded, doesn't seem to be an issue. anyone else have any insight on this? B2601 HST here.
3,316
Gently rolling (gears unloaded) changing is no problem.
