This helps a bit.
@PoTreeBoy brings up a good point about the solenoid in your tractor and it's actions.
It's kinda the reason I was trying to separate the solenoid and injection pump in this discussion.
So, on the 1105, I assumed it meant that energized, it turns the rack off. However, the solenoid appears to have 2 wire contacts in a picture I saw.
So I found this conversation: It is a Terramite with D1105 engine:
I have a piece of equipment(Terramite t7) with a D1105 engine. It's been running rough for a few days, and checking the service records shows me it overdue for filters. I replaced both(it has a small plastic trash filter near the fuel tank and the cartridge filter bolted to the motor) Fired it...
www.tractorbynet.com
Has some links to manuals as well as troubleshooting.
Also this is what
@PoTreeBoy was describing:
Interesting points about safety switches potentially causing starting issues.
I don't want to send you down the rabbit hole on this, but it occurred to me that we need to understand what and when the solenoid does it's thing
Also, you said;
I will try what you have suggested tomorrow and report back. I sent the pump away to be checked and injectors to be rebuilt. Engine was running very rough then would not start."
Also, if the solenoid is operating correctly, why is the injection pump not pumping? If the engine was already running rough, it is possible the lift pump had failed.
I am assuming that the injection pump was returned in good order and working properly as well as the injectors.
The lift pump may still pump when operated manually, but under load the diaphragm may leak and not produce enough pressure to load the injection pump with fuel.
If you go to the Fuel System portion of the manual (Page M25)
http://www.kubotabooks.com/AutoInde...es/&file=05 series engine workshop manual.pdf
There's a good description of how the system works.
However on page S-151, there is a procedure for checking timing. Note it says to remove the solenoid and push in the rack. (I guess using a punch or something) So it occurred to me; "when the solenoid is energized, does the plunger move IN or OUT"?
Apparently it moves OUT and that turns the rack on. Does your solenoid move in or out when energized?
(FYI, the solenoid on my L35 moves IN) to shut off the rack. But it also depends upon the geometry of your rack lever anyway as to how it turns off.)
I was thinking if you could eliminate the lift pump (or replace - you said you ordered one) and the solenoid from this troubleshooting process, and determine how the rack is supposed to be turned on, then you can determine if the injection pump is working properly.
