HST filter removal problem
HowardH
Kubota L4600
Apr 14, 2021
NE Alabama
I was trying to change the HST filter on my L4600 and have been unable to move with a filter strap wrench. Is there a special wrench. tractor has 460 hours
Well I got it off….. almost destroyed strap wrench. Chain wrench 👎 finally used a steel drift and hammer on the filter notches. After 3-4 good wacks it moved and was able to un screw by hand. 😁👍
6,883
This thread was a similar problem. Everyone has their own preferences.
TxTom
L3301
Sep 16, 2022
Leon County, Tx
That was me with the stuck filter. Use a long cheater pipe on your strap wrench but never admit on here that you used WD40 even if it worked.
2,833
I had the same problem a while back - I started with a piece of sandpaper inside the strap for grip - then I found a device that uses grit INSIDE the strap - bought it and it works very well.
One still might need a cheater bar too!
https://www.amazon.com/Lisle-57020-...fix=oil+filter+strap+with+grip,aps,59&sr=8-25
HowardH
Kubota L4600
Apr 14, 2021
NE Alabama
https://www.amazon.com/Lisle-57020-Filter-Swivel-Wrench/dp/B003969PKS/ref=sr_1_25?crid=N6T098QVVGIX&keywords=oil+filter+strap+with+grip&qid=1664999073&sprefix=oil+filter+strap+with+grip,aps,59&sr=8-25
I used one like this and almost destroyed it with a cheater bar :>(
JimmyJazz
1,263
795
Pittsburgh, Pa
I went to my local auto parts store and bought what looks like an adjustable plier type thing with vicious teeth for gripping. Worked great. My strap type wouldn't work either. Good luck.
5,697
Whatever wrench you use, place it as close to the bottom of the filter base as you can.
or better yet...
get the (*&%$^**( 'engineer' who designed the engine to remove the filter without having to spend 5 hours and $300 worth of gas to find THE wrench that WILL easily remove the filter.
The BEST filter design was on my '57 Willys Pickup. Top, dead center of the engine,EASILY undo one bolt,lift filter up,replace... you could do it in a tuxedo if need be.
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,119
3,381
Cap style don't work well? I ask because I've not yet changed the filters on my tractor yet. I was going to get the correct ones before even trying. I know the factory filters on any vehicle can be a bear.
5,474
2,169
18" channel lock never failed me but once or twice. In those cases, air hammer on the notched base. Comes loose every time.
HowardH
Kubota L4600
Apr 14, 2021
NE Alabama
Bobshinders
L3301 Kubota with loader
Oct 18, 2022
Edinburg, PA
That Hydraulic filter is just plain nasty. I have read and watched everything on this stuck filter and thought I was ready for my battle with the 50 hour break in maintenance... I was not. After breaking a three prong Amazon filter wrench, a strap wrench I found the magic combo for me. I mangled the filter before success, losing about 8 quarts in the process of an overnight leak from the mangled filter. You should only lose a few quarts if you change both filters quickly.
I don't believe the painting over the filter at the factory theory now that I have completed this trip to maintenance hell. It's just that Hydraulic filter is a super stressed, pressure filter. My magic combo for success was a vise grip style filter wrench with box wrench cheater. I first broke it loose (about 3/8" movement) with the large visegrip clamp seen in the photo. Good luck.
Bark
L4701/FM2560LA765/BB2560Pittsburgh disk Titan P forks
Feb 18, 2020
202
55
North CA
Like Motion said. Chain wrench.
Whiskey Mike
B2601 BX5455HD, RCK60-32,
Feb 16, 2022
42
15
Brewer, Maine
I did find a cap type that fit the three filters. However, the factory paint made those caps unusable at removing the original filters. A strap was needed to remove the original filters. Future changes should be easier with the cap wrench.
