Where does this wire go?
Nicksacco
Sep 15, 2021
675
382
Bahama, NC
My guess is based upon the wiring on my L35:
Both are thick wires so I believe something to do with the starting.
Does the tractor start?
Is the starter on that same side?
If yes:
The red may have been connected to one side of the starter with the heavy battery cable.
The striped may be on the other side of the starter, which is the starter relay.
The red would have power all the time.
The striped would have power when you turn the key to start.
I hope this is correct. Hopefully you have a wiring diagram
If you've got a multimeter - even a cheap one with a buzzer, you can trace the wires.
Disconnect the battery if you do this.
Northernsierras
L4701
Aug 5, 2017
johnsvill, ca
Thanks for the reply. The tractor starts and seems to run fine. I get error code p0202 on the instrument panel. Not sure what that is. I think if I can find where the wires go I can fix it fairly easy.
Nicksacco
Sep 15, 2021
675
382
Bahama, NC
Sorry I couldn't help but I'm not familiar with that machine.
I'm sure someone on here can help with the P0202.
My last shot is alternator. Any wires missing?
5,234
1,017
Pack rat chewed up the wire in the pic, its the only one i have found. Not sure where it attaches. Any help would be appreciated.
Thanks
I have pasted below the page from the Diagnostic Code manual.
Look at injector #3
I am not a code expert and just providing what I can find.
3,308
It goes to those wires that are chewed in the bottom side of the pic wrapped in plastic conduit. Make a jumper… wire them back together….then cover them ALL in conduit.
Find a cat.
