DVR
Kubota MX5400, L3560LE, L3301. KX033-4
May 8, 2020
121
68
Columbia, SC
Today I planted two food plots.
Used the L3560 and a perfecta 10 to turn them as deep as it would go, L3301 with spin spreader to spread the seed mix then L3560 and perfecta 10 set a little higher to turn in the seed.
Got one more to plant this weekend. Turned that one with the perfecta today. i'm going to disc it tomorrow with MX5400, then perfecta to smooth and bust clumps before seeding.
A one man 3 tractor operation
Chanceywd
Mar 26, 2021
764
722
central ny
My new wildlife pond dig continues. I was able to get a couple hours in today. I figure I am about 25% completed. 6 hours total time so far. A small dozer would have had it completed in the six hours with spare change! :) I enjoy the process. This pond will be around 3500 square foot and will require a clay, sodium bentonite or geosynthetic clay liner.
This trail cam has started taking foggy pictures. Its a cheap Moultrie that has been in service now for about 5 years. Not too bad I guess considering the extremes in temps here in central Wisconsin.
The deer can not resist fresh turned soil. When I arrived today the pond dig looked like it was rototilled! I have a new camera going in beginning of the week.
Last year with my L2501 I re-dug a small pond near the house that was a mud hole for years. It is only about 40' across and 7' deep in the middle. I plan on going around it and tapering the banks back more but this year got put off because of hand surgeries for carpal tunnel.
It is about 60 yards from the house and we sit on the porch in the morning to eat our oatmeal and fruit weather permitting to my wife's standards (she gets cold quicker than I). So as we headed out there a month or so back she noticed what looked to her like a branch in there and spoke of it. I grabbed the binoculars to look and quickly see it was a fawn near the edge. I ran out there and the doe took off but pulled the exhausted fawn out. It was breathing but had been unable to get out on the steep area. Laid it on a towel and dried it off. Left it and watched from a distance but mom didn't come back so I worked to stimulate and dry it more. After 3 hrs it started to sit up, and at 4hrs got up and trotted off to find mom. Still see this pair, we have been calling it Floatina or Tina for short.
Bill
mdhughes
L3901DT
Dec 10, 2014
1,413
1,337
Ste Geneveive county, MO
I think I posted the other day that I had installed the Summit 3rd function kit, but I didn't include any pictures. I 3D printed some spacer blocks to keep the hoses in line.
I also put two hose clamps on the loader arm.
Used the grapple for about an hour yesterday. So far I'm vary happy with it.
pigdoc
G1800S L2500
Aug 19, 2022
379
319
SE Pennsylvania
Checked the 'killer bushing' in the front axle pivot of my G1800. Still moves easily, put in 10 pumps of grease. [See one of lugbolt's early postings where he describes his trials on his G1900 with this piece.]
Checked the recently rebuilt spindles in the RC54 deck. Put 15 pumps of grease in each one. All is well. Looks like that new belt has seated nicely, and seals are sealing. [Pulleys got quite hot during the break-in, probably mostly from the belt.]
Lowered front outer anti-scalp wheels on the RC54 deck one notch to even out the cut height front to rear. Now exactly 2.5" from the cutting edges to the concrete garage floor, all around.
Thinking about installing a female garden hose fitting in the deck shell so that, after mowing, I can simply hook up a garden hose, turn the water on, turn the mower on, and flush out the adhered clippings. Thinking of locating it at the back edge of the deck on the left side, aimed at the spindle housing.
Opinions?
-Paul
Chanceywd
Mar 26, 2021
764
722
central ny
Opinions?
-Paul
Sounds good what you have done. One thing is most mowers recommend that the blades should be 1/2" lower in the front than the back so you are cutting with the tips and not creating drag with the blades. Don't know what your mower specifically calls for, just the rule of thumb I go by.
Bill
7,164
Got diesel in a 5 gallon can. Used the white “winter” power service additive. I understand it’s summer blend fuel right now.
Brand new Stewart’s gas station in town. They only have the large-size diesel nozzle with high flow.
Not conducive to filling cans. Probably my last visit there for diesel. Bet many others will do the same. Not a wise choice IMHO, and the old store was where I always got fuel.
Lots of guys and gals feed their diesel equipment from cans here.
5,161
Should have used the foam cannon in the shade so it doesn't dry on the paint. I found that it might loosen some of the grime, but I still have to use a brush or cloth to get the tractor clean. For that reason, I don't use my tractor because I don't want to get it dirty! :giggle:
S-G-R
Grand L5460, X1100C RTV
Jun 17, 2020
1,563
3,865
PEI Canada
No shade here until the sun sets. It isn't overly warm so the soap didn't dry.
dieselbob69
Kubota BX2380 (previously a BX1870 and GR2100)...
Jan 2, 2022
159
61
WNY
Switched out the R14t's back to turf tires till winter. No rain all summer now having to mow twice a week on softer lawn, R14t's are not kind to soft lawns. Rain starting to irritate me now, pretty much since I got the free fill it's been raining 2-3 times a week and making it a PITA moving it to where I want it....
ctfjr
L3800HST
Dec 7, 2009
1,982
2,539
central ct
If I wasn't selling mine I had drawn up a sketch much like yours to build.
S-G-R
Jun 17, 2020
1,563
3,865
PEI Canada
It will do for now. I need to trim the side pieces down about 6-8" which will tuck it in to the wall better.
BigG
Sep 14, 2018
1,953
774
West Central,FL
I wouldn’t make it too narrow. It will become top-heavy and easy to tip.
