B2601 seat issue.
johncrumbie
9
Covington, GA
Not happy with seat condition. MILSCO brand seat. Tractor 6 years old. Kept mostly covered.
May try KTAC which I retained. Any ideas.
I was able to adhere top with clamps and seems ok. Bottom is tough due to seat curve.
My plan is to glue and quickly hop in seat for a while.
Thanks
Steve67
B2601-fel, 60"mmm, 5' rear blade, balast box
Jan 20, 2017
354
141
St. Louis, mo.
I have the same tractor and seat which is five years old but the seat is still in very good shape. I’m thinking you have a seat that was not healthy from the factory. Hope Ktac helps you out
JimmyJazz
1,272
805
Pittsburgh, Pa
Gorilla glue would probably hold it together but it foams and is quite messy. If you try the gorilla glue do not sit on it as it will foam up and wreck your pants. Maybe put some bricks on the seat or use clamps of some sort. I use it regularly in difficult situations. Good luck.
Captain13
Feb 27, 2019
520
170
Kathleen, GA
I have a 7040 but last year, I pulled the seat and took it to a upholstery shop that does furniture and autos. The recovered the seat with a much better material and I have been very happy with the outcome. It didn’t cost that much (around $100) and came with a warranty on labor and material. Much cheaper that a new seat.
lynnmor
B2601-1
May 3, 2021
1,704
1,502
Red Lion
Does your 7040 have a two piece seat? I haven't found anyone to recover a one piece molded seat.
Captain13
Feb 27, 2019
520
170
Kathleen, GA
Yes. My seat is a two piece. hopefully You can find one that can do it.
fishdrivel
b2501
Nov 24, 2020
georgia
Thanks
Did you solve your seat issue? I have a b2601 with the same issue. It is the stock seat and a kubota seat is too expensive for my retired fanny. Anyone found a bolt-on replacement aftermarket seat?
