I just picked up a new to me BX2680. It has just over 200 hours, was owned by an older couple with small acreage and horses. Primarily was used to mow, both belly mower and they used a rear mount finish mower for the pastures.
Looking to see if I can get any maintenance records from the selling dealer. Oil filter is marked changed at about 100 hrs. Looking to see what I am going to do for maintenance right now. Starting with an oil change and will go from there. Had a few questions for the BX owners out there:
1. Oil weight, I'm thinking going with 10W-30, conventional or synthetic blend. I'm in upstate NY. not planning currently on winter operation, but I do typically run to Thanksgiving or a week later so there can be some 32F or lower temps. Kubota indicates 10W-30 or 15W-40 would work for my conditions down to 14F. Stopped by the local dealer and they recommend running 10W-30, probably because we do see temps lower than 14F. I see some owners running/recommending synthetic 5W-40 for lower temp operation. I don't know if I'm ready to go synthetic, probably stick with a conventional or synthetic blend for now.
2. Front axle fluid, looks as though not required to be changed until 400 hrs. Considering whether I should changed out to 80W-90 gear oil? I read some thoughts on gear oil providing better protection than the SUDT-2 fluid? Not sure on this one - not sure if operating under colder temps would lead me to one vs. the other?
3. Torn inner ball joint cover - one of the inner ball joint covers is torn. Kubota parts would be a new inner ball joint. I think I saw a youtube video of replacement of just the covers/boots. I don't see those listed on the Kubota parts site - are those available aftermarket?
4. Where to buy parts - first Kubota, so trying to find out any parts sources other than my local dealer. Dealer is a bit out the way for me, but not that far. I do like to have an online option, sometimes it is more convenient to order and have the parts delivered. Any online sources better than others or maybe at a discount that I wouldn't get at a local dealer?
Thanks for any help.
