I have a 326D 72inch disal mower changed water pump flushed raidiator every thing still runs hot help me please
So a question or 3. First and most important is why did you do all this work? "just because" and then the trouble? Or the trouble so rather than troubleshoot, throw stuff at it?I have a 326D 72inch disal mower changed water pump flushed raidiator every thing still runs hot help me please
I put it in the shop had them change the water pump new fan belt flush radiator totem it was running hot and it's still running hotMaybe your radiators cooling fins have debris stuck in them. Try to power wash the radiator. Get an inexpensive thermal temperature measuring device and make sure the engine is indeed running hot. You have not explained very well your circumstance. Good luck.
This^Take it back to the shop
The way I read it, he took it in and told them to replace parts, not diagnose the overheat issue.You took it in because it was running hot and it doesn't matter what they did, they didn't fix anything.
Check fan blades for any chips and make sure fins on radiator are clean also insure fan shroud is in good shape and clean air filterI have a 326D 72inch disal mower changed water pump flushed raidiator every thing still runs hot help me please
