Questions about an LX3310
kennykustom
Lx2610SU
Aug 16, 2022
Carberry
Looking at a 2020 Lx3310.
Comes with a big front blower and rear mower.
Seller doesn't know much about it, and am wondering about 2 pictures.
There is a switch on the loader control and 4 hydraulic connectors out back.
Can I assume 3rd function up front?
I've also only seen 2 hydraulic connections out back.... Not the 4.
Just a new guy looking for a tractor so don't destroy me E too much..
RMS
LX2610HSDC, RCR1260, PFL1242, LX2963, RB1684, WC-68,Flail Mower,Grapple, Z421
Sep 26, 2021
220
409
Buckfield Maine
The switch on the loader stick appears to be for a diverter valve. On my lx2610, this is used for the hydraulic snowblower chute controls. One direction is for left/right direction and the other is for up and down deflection.
kennykustom
Lx2610SU
Aug 16, 2022
Carberry
Is a diverter valve the same as a 3rd function ?
RMS
Sep 26, 2021
220
409
Buckfield Maine
No, the diverter uses the same hoses to switch between two fubction, a 3rd function valve adds another set of hydraulics to run a separate implement like a grapple.
Shekkie
LX2610, Virnig 60" Grapple, WoodMaxx TM-86H, Woods 60" BB/72”RB
Feb 12, 2022
183
306
Grafton, Ohio
I can’t think of a reason for a 3rd function without a loader.
AdmiralS
ToolCat UW53 (On Order), LX3310HSDC
Dec 7, 2021
15
12
Hudson Valley, New York
Also, those rear remotes are NOT factory/Dealer. The Dealer install will look like this. I have 2 rear remotes for a total of 4 connections.
BAP
Dec 31, 2012
2,756
869
Looks like it is to run the hydraulic spout deflector on the snowblower
Daferris
LX2610
Nov 23, 2021
483
403
Mid-Michigan
Those rear remotes are Kubota ones. The ones used on cab tractors are different than the ROPS ones.
LFP57
LX2610 Land pride QH 10, BB1560, EA 55" Wicked Grapple, Top n Tilt, Wicked T
Sep 21, 2021
108
38
No, these are for the CAB models only, the open station are mounted down below just like in the photo.
4,493
The remote valves are factory for a ROPS machine. The valves are the same but the outlets are base mounted to the work ports on the valves rather than on the back using hoses and push/pull couplers and mounting blocks like on your cab tractor.
nbryan
Jan 3, 2019
1,232
763
Hadashville, Manitoba, Canada
My loader hydraulic line connectors are what my B2782B snow blower's chute rotation and hitch lift cylinder are connected to. The loader curl function lines power the chute rotation, and the boom lines the lift cylinder.
