BX1500 radiator cap
mlan12
BX1500
Aug 13, 2022
11
Mossyrock, Washington
I am trying to find the pressure rating for the radiator cap on a BX1500.
With the help of the counter clerk at my local auto parts store we decided to try a 13 PSI cap. This cap has worked fine. Could not find a specific cap for a BX1500, but I did find a parts supplier who listed many models of Kubota tractors that used this pressure rated cap.
2,996
Could you not have just bought the proper cap from a Kubota dealer? What am I missing?
Fordtech86
L3200
Aug 7, 2018
4,976
5,917
Pineville,LA
13 is probably about right. Do you still have the old cap? It will probably have the pressure rating stamped on it, but it will be in bar not psi.
5,239
1,022
Please look at the Kubota spec which has a time for pressure to drop from 13 to psi.
Do you have that info for your $7.00 cap which is protecting your machine worth thousands?
Maybe I think differently at my age but for me peace of mind knowing I have not made a substitution which, because of my lack of knowledge of my machine's requirements, puts the risk of damage too high.
Pau7220
Aug 1, 2017
785
279
Scranton, PA
It has two jobs, raising the boiling point of the coolant and protecting the system from over pressurization. I would be shocked if any our techs ever tested a cap for leakage… Or if a $7 Stant cap wouldn’t be able to pass that test with flying colors.
My 3650 actually has a Lev-R-Vent cap and a Stant thermostat in it, both automotive. Upper Gates hose is from a Cobalt, I believe the lower is from a Civic. And a Goodyear automotive V-belt. All still in service without a single failure.
4,902
Radiator caps, the new oil thread! I wonder how many different opinions we can get on this topic. I just love all the bantering that ensues and it gives me great pleasure to read these types of posts late at night when there is nothing good on the TV.
Welcome to what brings joy to an insomniac.
5,239
1,022
With my very old Nuffield 465 I had to mix and match parts to keep it running as most maintenance type parts were no longer available.
What comes to mind when I suggest caution is a thermostat situation posted on this forum. The tractor was a new Kubota whose thermostat was controlling two water passages. The owner had bought a generic NAPA stat and now was having problems with over heating. In selecting the NAPA stat he did not understand the cooling system design on his tractor.
This is the example which comes to mind when owners start deciding what will work without having the background to make such a decision.
There are many members who are quite capable of making such decisions but there are also those owners who come here for help who are still learning
Pau7220
Aug 1, 2017
785
279
Scranton, PA
Absolutely agree. OP asked the question, and was given an answer. All is well in my book.
P.S.
All my filters are Kubota.
