Hey guys, new to the forum. I have a f2560 with a d1105 in it. It has 11 hundred hours. I bought it at an auction and it had a moderate knock/ clatter noise. I pulled the motor and did rod bearings and piston rings. Everything looked OK except for medium wear on rod bearing 1. I put it back together and the same noise is happening. I stupidly didn't pull the lifters or cam when I had the motor out. The motor runs and starts perfectly except for the noise. It sounds more top end rather than bottom. I triple checked my valve adjustment but noticed when I run it with the valve cover off, it sprays small droplets of oil out of both the intake and exhaust lifter areas (where the pushrods come up) on cylinder 3 ( closest to the flywheel) . It also smokes a little when reving it up from the same area. What do you guys think? Lifters?
Cam?
Cam?
