Want to do some arc welding on my BX23s loader to install hooks. Should I disconnect the battery? Any other issues I should be concerned about?
I did not disconnect for mig welding the hooks to the bucket BUT for tig I always disconnect, I fried some motorcycle parts with the high frequency. BUT your newer tractor may have a lot more computer stuff than my older b7800. Not that hard to disconnect.Make sure you have a good ground connection and as near to the point of weld as possible. I don't disconnect the battery when welding on tractor, but you do what you feel comfortable with.
As D2Cat well said - ground near welding area as for battery......
Unhooking the battery is a "good" idea - and gives you a chance to clean a terminal or two!!!!
Curious - bolting not an option? Reason being - not that a is not good enough, IF you pull a little to hard on something, the bucket metal could bend.
I supporting plate adds to the hook thus allowing more pressure to be placed over more area on the bucket.
Then again - many will say - the BX series will not be strong enough to mess up the metal on the bucket!
If I understand what you're planning to do, I don't recommend it. If you load one end of the adapter, you'll twist the adapter out of time. That connector piece is intended to withstand just the torque to keep the ends in phase so you can attach the bucket, etc. Many have twisted the adapter when one side of the bucket came unlatched.Thank you for all your quick replies. I do have a ssqa bucket however was thinking about welding some grab hooks to the ssqa plate. Can just remove the loader but didn't want to do that as many have had issues with reconnecting the hydraulic lines. I have owned the bx for two years and have never had a reason to remove the fel/bh yet. I have another bx I use for mowing and snow plowing. That way could lift without the added bucket weight and more visibility. I have seen others do this. Tks.
I welded my hooks to the large angle iron and bolted that large angle plate across the entire bucket top. Put hooks in line with the bucket arms.As D2Cat well said - ground near welding area as for battery......
i second the dont weld to your loader SSQA. put the hooks on your bucket!!Thank you for all your quick replies. I do have a ssqa bucket however was thinking about welding some grab hooks to the ssqa plate. Can just remove the loader but didn't want to do that as many have had issues with reconnecting the hydraulic lines. I have owned the bx for two years and have never had a reason to remove the fel/bh yet. I have another bx I use for mowing and snow plowing. That way could lift without the added bucket weight and more visibility. I have seen others do this. Tks.
This thread got me thinking about this. We all know that the current will take the path of least resistance so grounding near the weld makes sense intuitively. But perhaps we don't think about the fact that when a current passes through a wire it generates a magnetic field. If a wire moves in a magnetic field a current is generated in the wire. So when you're welding near electrical circuits, you might want to think about the magnetic field that's generated. If the field is moving, and wires are nearby, a current could be generated just like two inductors parallel to each other where one is energized by the other.This is an endless debate.
I'll just leave you with three questions:
- How hard is it to disconnect the battery?
- How expensive are your electronics?
- Why would you not?
But only IF the bucket comes off easily. Which is easier? Remove the bucket or remove one terminal on the battery? Don't know...In this case, it’s simply an academic argument. There’s no reason to disconnect the battery because the bucket comes off.
