Update to my previous thread, since I split the tractor again…
Backstory: pplate finger snapped and lodged between the housing and flywheel. Before this, clutch worked as it should.
I replaced pplate, TO bearing, and seals. Not much details in the WSM, so I used a parts diagram. Flywheel was/is good and so is pilot bushing.
After installation, clutch won’t disengage. At an idle, it will grind once before it goes into gear. With pedal still pressed, it will move forward/backwards. I adjusted the clutch play both directions. Since everything worked before the old pplate fell apart, I must have made an error during installation.
I split it again tonight. I think the disc was installed correctly with the taller hub side facing to the rear, correct? Could incorrect pplate finger adjustment cause the disc not to disengage?
The fork looked like it goes together one way. Am I incorrect?
I am stumped. Any advice is appreciated
