Virtual Guy
Kubota L2501, loader, Land Pride box blade and grapple, John Deere MX5 cutter
Jul 17, 2022
86
72
Osage County Oklahoma
Well, the positive side is that you have the grapple. Yes, there is a mess, but it can be cleaned up and then you can go enjoy your new grapple.
Oh yes, the mess has been cleaned up and I'm very happy with the grapple. Didn't mean to make it sound like I'm not. I already had a reason to be irritated at that dealer so I was just venting a little.
Flintknapper
L2350DT
May 3, 2022
2,021
2,568
Deep East Texas
Any way I can accelerate the growth of field grasses? Or maybe some ground cover that I don't need to mow? Creeping Charlie? Any recommendations?
I've never tried 'ground cover' plants....but it sounds plausible that if the soil will support it, it could possibly outgrow the undesirable weeds/plants and choke them out. I can't really help there.
Flintknapper
L2350DT
May 3, 2022
2,021
2,568
Deep East Texas
Man.....I'd love to have a grapple, leaking or not.
Envious of those who have one. But I don't think I can convince management (the Wife) that I really need one right now. I'll probably have to have a heat stroke first.
Hmmmmm....wonder if that is part of her plan. :(
7,379
The best way to promote grass growth is to simple keep it mowed. Weeds will be there but when the grass is mowed the weeds get mowed and they never get to seed. Without seeding they soon loose out to the grass and all you have is grass.
ve9aa
Apr 11, 2021
1,193
972
NB, Canada
Used the 'BX as a bead breaker.
Reactions: 9 users
radas
Mar 21, 2022
719
834
Installed my Pats QH. Those damn pins are so tight and my 3pt has not been used much. Ended up shaving off a tiny bit of the inside of my 3pt link bushings with the Dremel (mainly taking factory paint off) and tapering the end of the pins. Then I used some oil to lubricate the bushings and the pins. I spent another 35 mins or so making sure the QH was plumb and level. What a nightmare to install.... Here's the finished product:
Flintknapper
L2350DT
May 3, 2022
2,021
2,568
Deep East Texas
Is that the R14 tread type everyone is talking about? I kind of like that.
radas
Mar 21, 2022
719
834
Yessir. I'm a big fan of the R14s, it doesn't tear up my lawn and gets great traction in the dirt. I had to grind stumps on some sketchy hills that had been rained on earlier in the day and never lost traction in 4WD.
Trustable
l2501HST
Jul 5, 2022
300
259
Installed my pats QH yesterday. Wasnt to bad but those pins are a huge pain. My right side seems to angle a bit more than left so I’m gonna fix that tomorrow. I’ve used it for a couple hours and it doesn’t seem to affect anything. It was great not having to fight with the box blade, get the jack out, then lift it for just the right angle, then say some choice words while trying to get the other side connected. Didn’t even have to get a different top link, but I’m pretty close to the end so I am gonna go see if the extra long one from tsc is actually longer Than the stock one. Tomorrow I’m Lifting some 500lb steel beams with the welded hooks and lifting chains on the bucket for the neighbor. Was gonna get some pallet forks but I can’t justify the cost.
jyoutz
Jan 14, 2019
3,534
2,618
Edgewood, New Mexico
I decided that I needed a “glovebox” for small item and extra water bottle storage. I bought a 30mm ammo box and mounted it on the ROPs crossbar behind my seat next to the toolbox. One ubolt did the trick. Tomorrow it’s back to rotary cutting.
Virtual Guy
Jul 17, 2022
86
72
Pictures? I'm interested in something like this as well. Doesn't seem too technical but I would like to see how things fit. I literally need a box for my gloves. :D
gs1s
L2501 HST; Rhinohide Canopy, Wicked Tooth Bar, Pat's Easy Change
Jan 10, 2022
10
Did mine yesterday. Lots of fiddling with the set screws until I determined it to be "plumb enough".
Woke up today to a flat front tire after running the box blade yesterday. Slime to the rescue!
  • Sad
radas
Mar 21, 2022
719
834
Agree, the only thing I see now is that they are still "angled" when compared to the ends of the 3pt arms even though they are vertically and horizontally plumb. Not sure how to remedy that. It didn't result in any issues hooking up my BB although my top link is almost fully extended (need to get a longer hydro link).
10,497
Later today I'm heading over to a friend's place today to cut about 12 acres of his fields. I'll need to be back over there tomorrow morning too. Since I'll be putting the MX on the trailer I got up early and made up some D-rings which I welded in place, one on each side. I wanted the ring to be lower than the guard so that I can run a single chain through both rings if necessary. However, I intend to use a chain and binder for each D-ring with two more chains connected to a shackle on the draw bar at the rear for four points of connection.
I don't have 220V in the garage at the moment (don't ask) and so ran the Millermatic 185 off the Kubota GL7000 generator. Due to the thickness of the plate and required amperage It didn't go as well as I'd hoped. I've read that welding machines don't always work well when running off generators and that seemed to be the case this morning. Anyway, I got it done and it'll do for now, but I plan on eventually upgrading the spare MX grill guard that I bought from the Messick's auction a few months ago and will do a better job. I should have 220V back in the garage by then.
10,497
The new D-rings worked great yesterday. I only need a couple of feet of chain per side with these rings and certainly not the 20ft that I currently have at each corner.
10,497
It was 95F here yesterday afternoon and I was at my friend's place from 5pm to 10pm cutting 3ft to 8ft tall mix of grass, alfalfa, weeds and goodness knows what else. Early on I learned to go much slower through one type of weed that looks like very tall daisies (last photo). That stuff is brutal to cut. I had to remove a bunch of that crap out of the mower at one point. It was like wrapping up barbed wire on the drum! There was a group of thistles as tall as the cab ... I'm not kidding!! :oops:
The flail is doing well given the conditions, and the MX is awesome! I'm heading back out early this morning but will be on Flathead Lake this afternoon on a friend's pontoon boat so will have to go back out Sunday to try to finish. It's slow going but I'm enjoying it.
Reactions: 6 users
10,497
A few more photos from yesterday's ordeal. As the sun began to set the mosquito attack started it and it was brutal! Getting out of the tractor to grab a water, or unhooking the trailer when it was time to head home was no fun at all. One of the downsides of living alongside a river.
The grass on the right is taller than the hood of the MX, and those fricken' daisy things are taller than that with tough green woody stems. The worst stuff I've ever cut for sure.
Being able to offset the cutting head and not drive over the grass/weeds before cutting is awesome. It keeps a lot of the seeds and other vegetation off the grill, and not driving over tall stuff and laying it down prior to cutting helps a lot. I still have to learn where to place the front wheels so that I don't miss a thin section but I'm getting better. I've learned a lot about this flail running it for five hours yesterday and it's an impressive implement.
Last year I cut this field much earlier when it was green, and used the RCR1884 rotary cutter. It would be interesting to try the rotary cutter on this stuff to see if it's easier or better. It would certainly be faster but it's a 7ft model so not apples to apples.
Reactions: 8 users
10,497
Last photos before I head out ... to show off the MX6000.
Reactions: 7 users
Old_Paint
Dec 5, 2020
1,965
2,165
AL
50 Cal cans, one on each side. Made the brackets from 1" box beam to match the angle of the ROPS and hold it level. The holes drilled match existing holes in the ROPS. Not all ROPS have the extra pair of holes this low, so you might need to do something different for mounting. One of these will easily store a 20' 3/8" chain and several clevises. On the other side, I keep a few hand tools and a can of hornet spray.
