2001 BX2200 won't turn over... relay (re-)wiring question
Jeff S
07' L3240 HST , 72"clearing rake,RZ160 rotary,72"box B. , 84" harrows,48"forks
Jul 24, 2022
GA
I'll give it a try. Your blue wire should be connected to the Battery cable at the starter. Might be the black wire hanging free? Your yellow that I don't see other than at the relay should be going to the starter solenoid that is currently plugged into the blue wire. The white ground and the red trigger from the original start circuit appear correct.
Not related but trying to figure out how to do this posting thing. No response on previous attempts to "start a conversation " Hydraulic fluid periodically leaking from the split pin plug under clutch housing. Any one out there Experienced this?
Dustyx2
BX22, M7060, Landpride RC-2512, Woodmax SB84
Feb 19, 2021
217
NE Wyoming
Oops. I was still looking at the first pictures. Missed the post 11 picture. Still wonder what the black wire is.
5,235
1,018
Jeff
I am going to "Start a Conversation" with you.
Look for an indication near the envelope symbol in the top right page corner.
ve9aa
Apr 11, 2021
1,202
982
NB, Canada
You need to START YOUR OWN THREAD if you want help with your issues. I've seen a couple posts by you in others people threads (known as hijacking)
click "post thread", pick an appropriate category and give the title a descriptive name, go into the body of the message and tell us what the issue is. Continually posting your questions inside of others threads is considered bad form and won't get you any answers most likely. Seems like you're new to the Internet, so we cut you some slack. Good luck.
martinlaurentide
Kubota: BX2200, BX2750D, LA211, box; Woods: BH6000, Post Hole Digger-might sell
I tried to follow all the guidance but not sure I got it right. Before trying to determine which safety switch is blocking full 12v, can someone confirm if this is right or what I might still need to change? So sorry, I am just not very good at this frankly. I was able to get the starter to turn (although the machine didn't start, which I can deal with later) by crossing the main batter stud with the nut and the tab just to the left of it.
#40Fan
291
166
Now you need to make sure that you have 12 volts to the red wire in the top left corner when turning the key to start. You likely blew the fuse the way you had it hooked up before.
martinlaurentide
No and there was not before but there is continuity from the plug to the switch to both wires from the switch that cross the firewall to the starter area... Would that be because one of the safety switches is failing or because I need a new ignition switch... $130 usd... (or perhaps a cheap NAPA alternative). They all seem to use the same Kubota key anyway...
#40Fan
291
166
Continuity from ignition switch to that wire would indicate that the safety switches are working like they should.
martinlaurentide
- ah okay great. I wondered about that so IF I got or get the wiring eventually correct then it's the switch or connections at the switch. The green wire at the switch has been suspect since I unplugged and replugged it as it came out was loose but I thought I connected to that one of four pins... Thanks guys. I really appreciate it. I know it's a PITA but maybe aside from me this will help some other poor sap who sucks at electricity...
#40Fan
291
166
Where does the white wire on the right side of the picture go?
#40Fan
291
166
I went back to the first page and looked at your picture and it looks like the white wire is going up and behind the starter. I originally thought that was going to the starter.
But, now that you have that black wire hooked up, I can see that there is a terminal on the starter, next to the battery stud. Is that what you jumped to get it to crank over?
martinlaurentide
Yes. I crossed those 2 to crank it.
martinlaurentide
Where is this wire going?
Picture showed up late... oddly enough. That's a ground. I had wondered and reached behind and it goes to that bolt on the frame. It's the other black wire that I plugged into the starter that I don't really know much about.
