You may be on your own....I can't imagine anyone has a "database" of what aftermarket snowblowers will fit on the front a a Kubota, matched to their K-COnnect system..........but I've been wrong before.LOL Does an L series have a mid-mount PTO?\
Good luck !
its a 2 part scenario and yes it does have a mid mount PTO which is what created my problems.
My 2 problems with the mid mount PTO is that it spins at 2000 rpms ( I need it to spin at 540 rpm)
If there is a KIT to change the mid pto speed to 540 rpm then that would be perfect I can run a front mounted blower
the 2nd problem is that since I have a mid mount PTO I cannot install a front mounted PTO / 3 point hitch which would have allowed me to run any PTO blower I want
1. What front mounted blowers have you guys ran on your L5740? also has anyone run a hydraulic blower using a Power Pack ?
2. Are any of the front mounted blowers compatible with Kubota's K connect system
