BX23S Bigger Backhoe Bucket?
mdmoore00
BX23S
Jul 9, 2022
Montana USA
Greetings All, I have been digging septic infiltration trenches with my 12" bucket with ease and I am entertaining the idea of a wider bucket. I primarily dig in decomposed granite that comes out with ease and maybe a bigger bucket will save a little time.
Does anyone have a recommendation or can you help me better understand how to find a bucket that will work? What is the distance between pin holes I am looking for? I have a BX-Expanded quick attachment, does that help with finding a compatible bucket? Can a Kubota mini-excavator bucket attach?
Thanks,
Matt
Fordtech86
L3200
Aug 7, 2018
4,976
5,917
Pineville,LA
Kubota does offer a 16” bucket for the BX23S
P/N- BT2416
I believe you will have to go through the sales department at the dealer instead of the parts department.
pokey1416
Jun 24, 2020
556
825
SW Michigan
I went through my dealer for a 16” and it took a good while to get. Then dropped at local fab shop and had the teeth cut off. It’s nice to have both toothed and flat face available. I have the QA. I’ve heard of others that find buckets and order the “ears” to make them work.
This company might be able to help you with that.
https://poconometalcraft.com/collections/kubota
This place maybe worth a call too. I heard at one time they manufactured Kubota BH buckets for Kubota (info I have not verified).
https://werk-brau.com/about-us/
I’m using my FF for first time this week to excavate for a flagstone walkway.
Good luck.
pjoh784350
BX23, quick attach bucket, 3 point, pallet forks
May 3, 2019
162
71
Danville
Good luck.
The 16" bucket does not have bolt on teeth?
Dave Ogren
BX23S w/FEL &BH &60" Mowing Deck, 48" Dirty Dog Box Blade, 48" Tar River Tiller,
Feb 16, 2022
100
47
Asheville, N. C.
Thanks,
Matt
I also have the BXpanded Quick Change attachment. We also have a Kubota U17 mini-excavator with a 13" bucket and I was wanting to use the smaller bucket to see if the BX23 would dig better. They do not look as if they would swap and I have read that they won't, although I physically did not try to swap.
5,066
They will not swap.
Different coupler.
5,066
My 16" bucket has 3 teeth.
Good luck.
Land Pride has apparently made some buckets for Kubota, but Werk Brau seems to be the current Kubota primary supplier.
Werk Brau will not sell direct!
I called them several months ago.
I just bought a Kubota (Werk Brau) 16" quick attach bucket last week, for $1100, from Chappell Tractor in Milford, NH (have not picked it up yet).
I did so because Messick's has also had one on E-bay for 4+ months at #1100 plus shipping (est. $170).
It sold last week at $1100, and Messick's immediately listed another at $1428 plus shipping (it is still there....check it out). That is a 29.9% price increase.
For anyone close to Coleman's in Kansas, they still have one listed on their website for $1005.
That is one hell of a deal in today's market, especially if a buyer can pick it up rather than having it shipped.
BTW: If you buy two extra teeth, and two extra tooth pins,
you can have an adaptable smooth edge/tooth digging bucket.
Weld a 4" x 1/2 "piece of Ar 400 to the two outboad teeth. and you have a smooth edge bucket.
Knock out the two outboard tooth pins, pop the edge off, put on the two new outboard teeth, and you have a tooth bucket.
Back and forth the swap can be made.
The center tooth just stays there.
I plan to do this to my 24" bucket, to use as a narrow grading bucket.
4,899
re:
WRONG!
Check out Kubota K7873.......It is a 16" Kubota bucket (by Werk Brau for Kubota), and has 3 teeth.
hmm, picture in #3 post, NO mfr or part number, which I was referring to, the bucket does NOT have holes for mounting teeth. Around here ,we call them 'trenching' buckets ( leaves smooth tench).
5,066
re:
WRONG!
Since the new bucket was specifically "modified" to have the teeth removed, it might be reasonable to conclude that the "fab shop" welded the no longer needed teeth holes closed.
pjoh784350
May 3, 2019
162
71
Danville
re:
WRONG!
OP mentions having shop modification to remove teeth. My question was simply did it have bolt on teeth, which seems if it did why have shop do further modification? Just unbolt the teeth and you now have your grading bucket?
pokey1416
Jun 24, 2020
556
825
SW Michigan
Yes, the bucket came with 3 teeth. Kubota does not sell a FF bucket (I’m told). I ordered it last June(ish) and it arrived in April.
Here’s cost and a before pic. The teeth will interchange with my 18” toothed bucket so I kept them. I ordered a 16” because it was cheaper and most footings (for residential work) here in MI are 16”x8”.
torch
Jun 10, 2016
2,619
869
Muskoka, Ont.
I was thinking of doing something similar, but basically one big "v" tooth that would slip over all the teeth and pin to the back of the bucket somewhere.
5,066
"My idea" is not really "my idea"!
It is a suggestion by an expert at bucket manufacturer AIM Attachments, in Grove City, Ohio.
They apparently build buckets with the teeth/smooth edge swap option, on request.
I actually considered buying an AIM 16" Q/A bucket, but it is listed at being 63 lbs heavier than the Kubota/Werk Brau bucket. The AIM bucket price and shipping cost also just went up.
I found a Kubota/Werk Brau bucket at an $1100 "old" price.
Coleman Equipment in KS/MO has 4 of them at a still "older" price of $1005, but shipping would have brought that up to $1200 for me.
AIM buckets are sold on E-Bay under "bestattachments".
My L48 TLB is a strong machine, but is not as strong as a mini-Ex, so the AIM 63 lbs. of additional weight, way out there at the very end of the dipper, matters to me.
5,066
Kubota/Werk Brau buckets do not have bolt on teeth!
They have pin on teeth, and the root of the tooth is welded to the bucket.
Less expensive buckets often do have bolt on teeth.
pjoh784350
May 3, 2019
162
71
Danville
Yes, saw that in the picture he provided
4,816
My bucket tooth needs a root canal procedure. Any advice on how to start?
