LX2610 Oil Fill Location
Chilled h2o
Lx2610
Jul 4, 2022
Rougemont NC
I have a LX2610 which I just did my 50 hour service. After I changed the oil filter, I added the oil back into the tractor motor and I added the oil to the TOP oil fill cap(the oil fill cap is on top of the motor, right behind the air filter plastic canister). After that, I noticed an oil fill cap about 1/2 way down the motor.
Did I put the oil in the wrong location???
Did I mess anything up putting the oil into this location???
I checked the oil level on the dip stick and it is at the correct level.
thank you for the advise.
MOOTS
MX6000
Jun 27, 2019
1,925
2,210
Canton, Georgia
Nope. Two different fill locations for that engine in other applications.
Chilled h2o
Lx2610
Jul 4, 2022
Rougemont NC
Thank you for the response. So am I understanding that there are 2 locations to add the oil and either are ok? Therefore I did not mess anything up?
Thank you again for the reply
MOOTS
MX6000
Jun 27, 2019
1,925
2,210
Canton, Georgia
Correct. You are good if there is oil on the stick.
Fordtech86
L3200
Aug 7, 2018
4,976
5,917
Pineville,LA
X2 for what Matt says.
these engines are used in multiple applications, not just tractors.
2,921
1,383
I saw a V3800 engine in a horizonal boring machine a few weeks ago that had 4 options of where to add engine oil. Only 3 were accessible in that application though.
RalphVa
738
320
Charlottesville
The 3 JDs had those 2 locations. The B2601 seems to only have the top one on top the valve cover. That one is easier because it isn't slanted like the one on the 3 JDs down low in the front. The Isuzu has both like the JDs had.
