Front Axle Seals
Rrkpitt15
B7500
Jun 25, 2022
Pittsburgh, PA
New Member and Owner here:
I was lucky enough to talk the owners of the house i bought to throw in the 2003 B7500. I dont know how well this thing was kept up with but it looks good for a 2003.
I was moving a little dirt today and noticed that there was some fluid coming from the hubs. Im assuming its the outer axle seals. Job doesn't look to be too bad but this is my first Kubota and diesel. I have experience working on cars and small engines but no experience with these things.
Should I do the outer seals too? Anything to watch out for? Any other things tend to wear out on these things?
Thanks for the help.
woodman55
L6060HSTC, RTV 1100
May 15, 2022
1,050
869
canada
I would start with a work shop manual. I just checked and they are $29. It is a pdf file. Well worth the money. Just google Kubota B7500 WSM
Nicksacco
Sep 15, 2021
757
493
Bahama, NC
I found the parts manual here for B7500 - will this help you?
Look at the front axle sections for parts.
I did all the front seals on my L35 which is quite similar to your B7500. Wheels, steering hubs, etc.
Plan ahead with lots of time and plenty of cardboard on the floor!
It's a lot of work getting the old seals out - but not impossible.
It's heavy! I removed the axle from the tractor to perform all the work.
Use of 80-90 Gear oil or UDT will work for a refill.
There's lots of help on the forum,
MINICUP28
B7610, KX-018, RTV-500, JD X758
Feb 21, 2019
102
50
COBLESKILL, NY
My tractor does that in hot weather because the front axle filler plug does not breathe. I made a vent hole in it and the leaking stopped.
Rrkpitt15
B7500
Jun 25, 2022
Pittsburgh, PA
It was hotter than normal yesterday. Did you just drill out the plug and use a relief valve or run a tube up into the motor area?
3,330
1,748
Do yourself a huge favor and replace the failed oil seals. Adding an unneeded vent is just putting scotch tape on a broken leg.
Resmith1066
2003 B7500
Jul 23, 2022
Carthage Tx
I'm handy with a wrench, but not a mechanic by any means and I replaced both of mine without too much trouble, get a really good set of snap wring pliers. There are plenty of good resources on youtube. I did vent the filler plug as well.
#40Fan
460
316
Pay extra attention when you get everything apart. What I would call the spindle, piece that has the ~90° bend, can crack.
