Two separate valves and sets of cylinders. The 3pt will not make the loader drop and vice versa.When parked or operating the B7200 the front loader and the 3-point hitch slowly lowers. Is this from the control handle or elsewhere?
Yes. Is it a B1630 loader? What is drifting down on the loader - the bucket, the boom, or both?Thanks. So there is a valve and cylinder in the front loader hand control and another set in the 3-point handle?
Just to clarify, is the problem that the FEL and 3PH lower when you don't want them to, or that they lower slowly instead of fast?When parked or operating the B7200 the front loader and the 3-point hitch slowly lowers. Is this from the control handle or elsewhere?
Both and the 3-point hitch.Yes. Is it a B1630 loader? What is drifting down on the loader - the bucket, the boom, or both?
They lower when I don't want them to. They work fine with the controls in all directions.Just to clarify, is the problem that the FEL and 3PH lower when you don't want them to, or that they lower slowly instead of fast?
They also lower with or without the engine running.They lower when I don't want them to. They work fine with the controls in all directions.
I have a B7200 with B1630 loader and have the same problems. These machines are getting old and worn.They also lower with or without the engine running.
Thanks. That's what I figured, and clearly everyone else too, but you know what they say about "assume".They lower when I don't want them to. They work fine with the controls in all directions.
Dan -- I'm curious why you favor the control valve being the cause as opposed to a failing seal in the cylinder? Is it worth performing necessary diagnostics to confirm this hypothesis, or are you suggesting that OP just go ahead and replace the control valve?In the case of the loader the control valve is probably shot. Good news is its inexpensive and easy to replace. I'd suggest you make it the number one priority.
The lift cylinder has to retract for the lift to drop and with a leaking seal that cannot happen. The oil has to either escape to the outside (external leak) or back to tank through the control valve.Dan -- I'm curious why you favor the control valve being the cause as opposed to a failing seal in the cylinder? Is it worth performing necessary diagnostics to confirm this hypothesis, or are you suggesting that OP just go ahead and replace the control valve?
--eric
Not to question the wisdom of the Hokie…. but if my tractor is not running and both FEL and 3pt are in the air… dropping the FEL by moving the joystick….WILL move the 3-pt also.Two separate valves and sets of cylinders. The 3pt will not make the loader drop and vice versa.
Leys assume the typical Kubota loader valve configuration.Not to question the wisdom of the Hokie…. but if my tractor is not running and both FEL and 3pt are in the air… dropping the FEL by moving the joystick….WILL move the 3-pt also.
In fact, it the 3-pt is on the ground…and the FEL is dropped…the 3-pt will move slightly towards “up”.
I’m off on a trip…so I’ll have to see if I remember things like I. think I do when I return home.…if I can remember to remember to try it again….Leys assume the typical Kubota loader valve configuration.
The 3pt is being held up by the oil trapped in the lift cylinder. The 3pt valve is maintaining that seal.
The loader is being held up by oil trapped in the lift cylinders. The loader valve is maintaining that seal.
When the loader valve is shifted it opens the loader cylinders to power beyond and the oil flows through the open center in the 3pt vslve and back to tank. The spool in the 3pt valve never moves just like it does not move when the engine is running and oil from the pump is houng yhriugh the center. So how can the 3pt drop?
BTW I lower the loader with the engine off all the time and the mower in the back stays right where it is until I lower it with the position control lever.
Oh yeah that's right ... because the rod-end volume is less than the cap-end volume. You already schooled me on that, and then I watched an entire training series on hydraulics that included calculating rod-end and cap-end volumes, extension and retraction times, etc. Hadn't yet directed that knowledge to apply towards diagnosis. Thanks!The lift cylinder has to retract for the lift to drop and with a leaking seal that cannot happen. The oil has to either escape to the outside (external leak) or back to tank through the control valve.
I'm going to have to bone up on "typical Kubota loader valve" ... I would have thought that the loader valve opens the loader cylinders directly to tank, not power beyond. I'm very interested in the hydraulics plumbing on my tractor, and it's on my to-do list to take another look at the diagrams in the WSM.Leys assume the typical Kubota loader valve configuration. . .When the loader valve is shifted it opens the loader cylinders to power beyond and the oil flows through the open center in the 3pt valve and back to tank.
