b7100hst 3 point hitch seeping
cmustang
B7100hst 50" tiller Dodge 2500 diesel 700 Grizzly 79 K5 blazer 40" Boggers
Jun 9, 2012
39
Mayerthorpe, Alberta, Canada
I have a b7100 old stile and the 3 point hitch leaks down eaven with out weight. I am leaning towards rebuilding the control valve but there are other points where the problem could be. Has any one had this problem and where did you find it thanks in advance
hodge
Nov 19, 2010
2,906
453
Love, VA
How much does it leak down? Are you talking about overnight, while it's running, during use? Mine leaks down overnight- it functions fine.
cmustang
Jun 9, 2012
39
as soon as i got it about a month ago i split the hst filter no foreign objects and the fluid looked fairly fresh nothing in the screen also
Kytim
B6000DT, B7100DT,Snowplow, RM360, Scoop, Cultivator, Carryall,Disk, plow
Aug 14, 2009
848
12
Western Ky
On mine I had a slight leak on the "cap" of the lift cyl.(right in front of the seat) I didn't think it was any big deal. that was until it popped the big "O" ring. sucker became ol' faithful while I was on her!!! lots of high pressure oil up!!, then down everywhere.
Didn't you have something similar Eric?? Maybe it was someone else.
New rings all better,been 2 yrs now.
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
Richmond Va
Ya know now that you mention it, I did have to crack open the lift clyender area thats located under the tractor seat. There was a bunch of bolts and it was a nightmare going in there, but I'll be damn if I can remember what I went in there for!
Buse
B6100 with FEL
Oct 3, 2011
40
Sweden
I guess I have the same issue as cmustang: My 3point will slowly fall during any operation (i.e. as long as the engine is running). It is a B6100D with FEL and 3500 hours on the clock. When I put on the counteweight the hitch drops from top to bottom within 3 hours. Nothing happens when idle in the garage. In additiion , there is a small oil drip inside the left rear wheel.
hodge
Nov 19, 2010
2,906
453
Love, VA
You just had a birthday, right? Age will do that to your memory...
cmustang
Jun 9, 2012
39
no leaks to the exterior it must be a relief valve or o ring I'm thinking it must be the control valve or in the cylinder it self with my luck it will be the last place i look so i was hopeing someone has had the same issue to narrow my search
Ach
Kubota B6000 DT with B219 Loader
Mar 1, 2011
72
Big Island, Hawaii, USA
I just replaced the o ring on the 3ph cylinder for my b6000.
Very easy task. Six bolts on the top front of the transmission housing provided access and manually raising the lift arms allowed me to push the cylinder far enough out to grab hold of the piston.
Not sure if the b7100 or the hst nature of it would change things, but I'd start with the o ring.
cmustang
Jun 9, 2012
39
Ordered parts today for the o'rings and packing on the lift cylinder. came to a whopping 10 dollars including the o'rings for the divert er valve (may as well change them while its apart) As soon as i get them picked up and installed ill let you know how it went
2,681
Bummer! I hate it when that happens..... you get all physiqued up.....
cmustang
Jun 9, 2012
39
Well finaly got time to get to fixing. I was able to get the piston out threw the front cover. I think at one time there was a pump failure as the piston and the cylender walls had scratches on them some fairly deep. I managed to get all the sharp edges off with emery cloth. Now that i got it back together it all works fine if it lastes for any length of time (more than a few years) it will be worth just changing them again but if it dosent i gues ill have to change the housing. Thanks for all the help
