Small Offset Flail-type Mower?
River19
B2601, RB1560, BB1260 and BX2830 blower
Sep 10, 2020
351
665
NH/VT NEK
Is there such a thing as a small offset flail mower that would run on a B2601?
I have a couple use cases for this.............I have a long 600'(ish) driveway and I would like to periodically cut the weeds back along the edges without having to manually hit it with the string trimmer which is a PITA. I also have a couple hills with rough cover (ie. grasses, weeds, wild flowers, etc.) that need to be maintained as I will be having a solar array installed on one hill.
A rotary cutter would work for the hills but the sides of the driveway would really require an offset to not roll into the ditch......ideally.....
I know the ditch mowers are awesome but they would cost me > $50K as I would need a tractor upgrade and that isn't happening lol (love the 2601).
Any thoughts?
JimmyJazz
1,273
805
Pittsburgh, Pa
You can often find used tractors with flail mowers for sale on tractorhouse.com often priced relatively inexpensively. Type flail under keyword. Might be worth a look.
bucktail
Jun 13, 2016
1,288
216
MN
Would a sickle mower work?
Crash277
BX23S
Jan 17, 2021
844
623
Anyone have any experience with the "Victory Implements" stuff? 40" offset Flail for ~$2K
that is amazing!! i think im going to have to add that to my "wants list". sure would be handy to keep my pond edges looking good
River19
Sep 10, 2020
351
665
NH/VT NEK
I'm sure it is made of Chineseium but still for the average Joe doing residential maintenance it might be fine.......I thought it was interesting.......
Elliott in GA
Mar 10, 2021
860
863
North Georgia
If you want an inexpensive solution that will probably last (a cheap flail that is junk within a couple of years is no bargain - I have no knowledge about the quality of the EMSD-40), you might want to look at Sabre Samurai (less than 2K, if you already have a 3rd function or diverter). You might also be able to reach much further using the FEL versus an offset on the 3PT.
River19
Sep 10, 2020
351
665
NH/VT NEK
Thanks, I can take a look as I do have a 3rd function valve already......and no use for it ......yet....lol
11,725
I have a Del Morino Centurion Super 158 that's made in Italy and looks a lot like that EMSD-40 but cost three times as much. The Del Morino is a slick mower but that Chinese made EMSD might be slick too if it was reverse engineered properly.
