Can't answer your question but what are you trying to accomplishView attachment 81184
I don’t have a flow diverter valve for the three point cylinder on my tractor. Is the valve a option that my tractor didn’t come with? I don’t know what year the tractor is, but it is later than any S/N I can find on line.
I’m exploring the idea of a hydraulic top link.Can't answer your question but what are you trying to accomplish
You just need the hydraulic outlet cover which gives you ports for hooking up an auxiliary valve.I’m exploring the idea of a hydraulic top link.
Mine is already in use for the FELYou just need the hydraulic outlet cover which gives you ports for hooking up an auxiliary valve.
Then you daisy chain any additional valves off the loader valve. You can connect as many valves as you want one right after the other.Mine is already in use for the FEL
Yes it was an option to get that diverter valve. Using that would be very cumbersome. When turned the 3 point hitch will not operate. So you would have either have use of 3 point or your rear remotes.View attachment 81184
I have very limited knowledge of hydraulics, but I’m going to go with my limited knowledge, and say I would need a open center control valve, and I pick up fluid from the return side of the FEL valve, and return back into the block? I’m guessing that I would need a pressure relief valve on the top link valve as well, and it would T into the pressure relief valve line from the FEL control block? Or would that cause issues? I wouldn’t think so, but limited knowledge being what it is, limited.Then you daisy chain any additional valves off the loader valve. You can connect as many valves as you want one right after the other.
No - the tractor alfeady has a pressure relief in the circuit. All you need is a new control valve with a power beyond port. Connect it as follows:I have very limited knowledge of hydraulics, but I’m going to go with my limited knowledge, and say I would need a open center control valve, and I pick up fluid from the return side of the FEL valve, and return back into the block? I’m guessing that I would need a pressure relief valve on the top link valve as well, and it would T into the pressure relief valve line from the FEL control block? Or would that cause issues? I wouldn’t think so, but limited knowledge being what it is, limited.
