LA435 Loader keeps uncoupling
Cadman500
B2601 with LA435 Loader
May 31, 2022
Corona ca
Has anyone had this problem?
I only have 28 hours on my B2601 with a LA435 loader And the dang loader keeps uncoupling.
its happed 4 times now and has now damaged my hood.
it happens when scooping or carrying a load.
I have checked and it looks like it is locked all the way. 2CAB574E-29BB-4B34-87CB-BCCAF484E4F2.jpeg
7,463
Do you pick up the bucket a couple of feet at look at the pins to see that they are in fact in the holes properly? You may have had one pin not locked in and the bucket came loose and bent the attaching plate so the pin can not lock (until you get the plate back into the same plane as the other side).
Cadman500
May 31, 2022
Corona ca
There is no pins it’s a auto lock. (See picture)
If I bump something to hard or lift a lot a weight the auto locks just come right off.
I don’t think I am the only one as I have seen a guy on a video talking about other people having the same thing happen. It’s kinda scary and dangerous.
Cadman500
May 31, 2022
Corona ca
Maybe this will help.
yes that’s a good video. He says try and clean it.
I just thought maybe some one on the forum has heard about this. Sure wish they would just have used a pin.
edritchey
2026 Kubota T2290-48 2026 Kubota ZD1211L-3-72, 2025 New Holland CNH WM75
Jul 19, 2014
1,178
930
Wellsville, PA
I got mine to work really good after fixing the bent parts and adjusting everything correctly but I still installed a couple custom pins just to make sure it's not coming off. The pin diameter is 18mm I don't remember the length when I have it off again I'll measure them I think they were cut to 4.5" once they are installed there is no way for anything to pop off. But it defeats the easy off design these loaders were made for.
Cadman500
May 31, 2022
Corona ca
Update on my tractor.
So it turns out Kubota has a recall bulletin on these loaders uncoupling.
Took it in to my dealership and they say Kubota will replace the towers With a new
changed version.
Now the only thing is trying to get the parts. They have had my tractor
Since may/June and can’t get the parts.
They did replace my hood that got damaged from the loader coming off.:)
I was wondering does anyone know how to see these bulletins?
B2601 with a L435 loader serial number 72691
jkrubi12
Sep 24, 2012
403
302
right coast
@Cadman500, what year is your loader/tractor? My 2022 loader has a serial number in a distinctly different format, I'm wondering if there has been some sort of change which may eliminate my loader from such problems. Although I've seen other users report the same issue, I've had no such issues with mine.
Cadman500
May 31, 2022
Corona ca
The tracktor ser# is 72691 and the loader # is A8435.
From what I understand is they changed the towers.
I don’t know if it was a change or just bad batch.
Towers Thats the part that is bolted to the bottom of the tractor
then connects to the loader.
The service guy told me it’s a slight change to the welding? On the coupler.
He also said it was a certian set of serial numbers only.
Just wish I could see this bulletin to explain this better.
jkrubi12
Sep 24, 2012
403
302
right coast
OK, my loader SN is the same format as your loader SN. Keep us updated on how the warranty process shapes up, and post any info on that recall notice if you get a look at it. Good luck!
Cadman500
May 31, 2022
Corona ca
Well after waiting 4 months still can’t get the parts from Kubota.
So I took the tractor back from my dealer and put these pins in For now.
So now their is no way it can come off.
McMaster Carr #98497A664 Pin and 98017A220 Washers.
B88B0989-67A0-4B5E-A89B-E5ED042B8EAC.jpeg 089EA965-4CBB-41C7-A539-954319A24633.jpeg 9183C521-0424-4A41-B60C-896842C2841B.jpeg 8CEB5C19-FCE5-4E2F-ABAF-62A6D7992768.jpeg
jkrubi12
Sep 24, 2012
403
302
right coast
Solid fix, great pics. Unfortunate that you are still waiting on a Kubota solution, but your solution is first-class. Thanks for the excellent update! (y)
