B6000 Battery Charging Problem
Chanceywd
Mar 26, 2021
791
767
central ny
The concens
The consensus I have gained from Kubota tech's who work on these machines as a profession is it is a mistake to rely on cheap meters to do diagnostic tests.
Diodes fail in several ways. Keeping in mind the diode's main job is to block one half of an AC signal, I have seen unexpected signals when trying to determine if a battery is being charged.
If things do not make sense with voltage readings, the first thing I do is to change meter scales from DC to AC.
If I am reading AC at the battery my findings are generally there is charging system trouble.
There are forum members whose electronics knowledge is much greater than mine and they may have comments to provide.
I have to agree Dave, I always check for ac when checking any charging system. Even small engine and motorcycle I have found it to be helpful. I usually grab my fluke 87 not the cheap meter.
Bill
5,255
1,053
I continue to be puzzled how on the B6000 the headlight switch can produce 2 levels of brightness.
I wonder if the correct headlight switch is installed in the B6000 as the Operators' manual only shows a two position switch.
If you look at a later B model, namely a B9200HST, its headlight switch has the 3 positions b ut this is matched by headlight bulbs which two filaments.
None of this is particularly important as the three wire dynamo only had a short life with Kubota. John Deere uses a much higher output 3 wire dynamo on its newer tractors.
Oldie68
B6000
Nov 21, 2021
60
Yarker Ontario Canada
Not sure about the original or not headlight switch, but the bulbs in the apparently original headlights seem to have two filaments (not exactly sure) but the bulb number is 1156. Definitely a 2 position plus off switch, and from the rear connections aside from any noticeable identification markings appears original??
As I've stated I'm still learning about this unit. Trying to get the things that aren't/werent working to work as they should or better. Am I to believe that an alternative dynamo/alternator could be utilized? Such as from a john deere?
Oldie68
B6000
Nov 21, 2021
60
I can't recall but think i have only 2 wires to each headlight
Mark_BX25D
Bx25D
Jul 19, 2020
2,048
1,570
An 1156 bulb is a single filament bulb. Should have two wires - power and ground.
Are there two bulbs in each housing, perhaps?
Not a problem, in theory. Conceptually, swapping in a different alternator for your alternator should be pretty straightforward electrically, and swapping a different dynamo for your dynamo should be straightforward electrically. Alternators and dynamos are very different, though, so swapping in an alternator for your dynamo, or a dynamo for your alternator, would be complex.
In practice, it's not that simple. A different alternator might have very different mounting characteristics and space requirements, for example. Alt for alt will mostly be a physical challenge, same for dynamo for dynamo.
All theoretically doable, though, and it's probably been done very successfully. It all depends on what it's worth to you. You'd probably be spending a lot more effort that any improvement would be worth in practical terms.
4,001
The elect schematic above shows a dual element bulb…in which case the 1156 is an INcorrect bulb.
Oldie68
B6000
Nov 21, 2021
60
Ok, got it, 1156 bulb single filament, only one 1156 bulb in each headlight assembly. Two wires power and ground.
Regarding a dynamo or alternator swap, of course, each might present their own mounting challenges. I'd only consider an alternator swap if it was feasible for mounting, the dynamo also if mounting was straightforward, or retrofit in tge same loaction as OEM.
I will however inspect and attempt to follow suggested troubleshooting/testing of rectifier.
Thanks to all for info.
4,001
The socket from my recollection is same confiuration for the 1156 pin type so??
Not sure what you’e asking by “so??”… but, for example, an 1156 socket would have a SINGLE contact inside its’ base…while an 1157 dual-filament lamp (which outwardly has a similar appearance) will actually have TWO contacts within its’ base. Furthermore, the 1156 socket (BA15S type)has accomodation for two pins in its’ sides that accept the 1156 equi-depth pins of the lamp…while the 1157 socket (BAY15D) type) has similar accomodation for two pins…but those 1157 pins are at different depths so that the lamp can only be installed in the correct orientation for the differing levels of illumination of the dual filaments.
See this illustration for the differences:
Oldie68
B6000
Nov 21, 2021
60
Not sure what you’e asking by “so??”… but, for example, an 1156 socket would have a SINGLE contact inside its’ base…while an 1157 dual-filament lamp (which outwardly has a similar appearance) will actually have TWO contacts within its’ base. Furthermore, the 1156 socket (BA15S type)has accomodation for two pins in its’ sides that accept the 1156 equi-depth pins of the lamp…while the 1157 socket (BA15D type) has similar accomodation for two pins…but those 1157 pins are at different depths so that the lamp can only be installed in the correct orientation for the differing levels of illumination of the dual filaments.
OK thank-you for the illustration. I believe from recollection the bulb and socket is a BaA15S 91156) single contact bulb, as I attempted a couple of 7056 LED bulbs but didn't quite work as I had expected. So these I know are the BA 15S type base/contact.
Oldie68
B6000
Nov 21, 2021
60
Thank you I have the type switch as in this example but of course no symbols or description on the dash to indicate anything as such. The headlights operate on both ;positions although I don't a significant difference in brightness (maybe a teensy bit brighrt on second position, especially after finding a red wire on the switch going to the rectifier broken off, resoldered it back to switch)
4,001
Note: I edited my post #30 above to point to the BAY15D difference (dual contact, different-level pins)
2,732
I have 3 wires in total coming from the dynamo, and a 2 position headlight switch, (off, 1st position and 2nd position)
You may be able to look up a label part number for the switch for lights and find an image of the label to see what the function was
Cat-herder
B6000 with home built front loader, K-42 rotary tiller
Mar 5, 2023
Eastern Washington US
Good morning all!
New here so of course I'm going to resurrect an old conversation as it applies to my current issue.
I have a B6000 with the 2 wire dynamo, dual range headlight switch with single element bulbs. They don't work because the sockets fell apart but I don't need them anyway.
Aside from that my issue seems to be opposite of most of what I can find in searching the forum. My charging system is not stopping. Battery is overheating, acid all over the place, and with a meter on it yesterday it went well over 17 volts before I decided not to burn up my meter and shut it off. I bought the tractor a couple of months ago and not used it much so don't really know the history other than it looks very original. Seller did say he thought it might need a new battery but I'm thinking the rectifier must also regulate voltage?
Anyone have helpful advice for me on this?
Thanks!
2,732
You will have to correct the regulator side of the charge system.
try to take and post pictures of the regulator if you can find it.
some of the older Kubota models have some strange regulator systems that can cause problems to fix since they are obsolete.
hopefully someone more experienced will be along to help you
Cat-herder
Mar 5, 2023
I learned a lot today. Chiefly I learned to actually read the emails from this site that say "do not reply to this email". I did a couple of updates but now understand you need to be on the site to post updates. Live and learn I guess.
As to the charging issue, it turns out the rectifier/regulator has a terminal labeled "E", as in earth. As far as I can tell it never was grounded, hence it couldn't tell what the system voltage was and kept charging away.
Once I grounded that terminal it settled in right about 13.7 volts or so. I can live with that. Now to neutralize the spilled acid and check electrolyte levels.
I also replaced a couple of fuel pump wiring splices, replaced the injector to tank return lines, and turned the fuel tank straps around the right way so the bonnet actually closes correctly. I'm OK with those things for the day.
Next step is to change the angle of the main loader cylinders so they move at a reasonable rate but that's for another post.
2,732
Great that you have the charging system worked out now and thank you for coming back to post about the fix.
Good luck with the battery acid remedy. It always seems to keep rusting away when I have the problem.
Marcel21674
Netherlands
I have marked up the 3 wire B6000 wiring diagram in two formats. JPEG and pdf. The pdf is attached and the JPEG is immediately visible. Depending upon your computer and printer one format may print more clearly than the other.
In the box showing the circuit diagram of the Main Switch, the Starting Switch and the Light Switch the light switch box says both positions 1 & 2 are the same. One position is not brighter than the other.
The dynamo is putting out 3 phase AC voltage. One pair of these phases is used to charge the battery thru the rectifier. These are colored Purple and blue,
Another pair is putting out AC to the headlight. These are colored Yellow and Purple,
If you try replacing your existing headlights with LED's most LED's wont work on AC. A few owners have reported success with LED's but I have not seen this myself but these products are always evolving.
The headlights are not high and low beam. The headlight brightness will increase with higher engine rpm.
From what i can see. The headlights are not AC powerd but just 12V DC.
I don't understand why, but it seems that the yellow and purple indicaded generator leads are short circuited when you turn the lights on.
