Kubota x1100c problem....
pdgriesse
granville,ohio
Hello----My Kubota RTV does not move when I shift into any gear but the speedometer displays the speed as I press the accelerator pedal. If I engage either the Posi traction or the 4 wheel drive lever (or both) it DOES move and seems to respond normally. Whats going on? possibly a sheared axel key in the rear or ???? many thanks for your help!!! Paul
3,572
2,001
You have either a failed CV joint or a stripped spline in one of the rear wheel hubs. Jack the rear wheels off of the ground, with the park brake set, and see which one of the rear wheels will turn by hand.
pdgriesse
granville,ohio
Thankyou for your prompt and accurate diagnosis! I found the culprit--- R- rear wheel spins freely. I`ll pull it down and expect to find a stripped hub THANKS!
Edke6bnl
B7800 Kubota, case 1840 Skidsteer Ford 3500
Mar 31, 2022
259
144
Agua Dulce, California
Exactly, just found a stripped spline on the brake drum on my mule, did the same think
pdgriesse
granville,ohio
Splines on axle OK----problem was a broken 6 ball bearing on lower axle joint ( I guess this replaces the u-joint?) Required a complete new axle. Not cheap---
