Cheap way to add a blue tooth radio to a kubota cab tractor
woodman55
L6060HSTC, RTV 1100
May 15, 2022
991
808
canada
I cheated and went with noise canceling headphones, takes out the tractor noise and sound quality is better.
Plus you can use them for yard/shop work, not just tractor work. Can I ask what brand/model you purchased. I am looking at the isotune brand.
3,095
In answer to my own question, it seems like it is not a blue tooth radio, but rather a blue tooth device that connects to a smart phone or similar device, and plays sound that originates from the Bluetooth transmitter in whatever device you use as the source signal?
Maybe it is a radio, and has a blue tooth connectivity function. Guess I better go back and see if the answer is in that video that I did not view... :unsure:
Hkb82
Nov 17, 2021
426
347
Ontario Canada
Sardillim where did you get the front pod speakers you used? They look great and I’d like to add some to my cab also.
pokey1416
Jun 24, 2020
567
843
SW Michigan
Thanks to Maine Farmer I got my radio in yesterday. I initially bought a harness from my dealer but noticed it only used 6 pins (on the 9 pin plug). I figured I needed at least 7 so ordered another via eBay. Turns out the Kubota OEM radio plug for Grand L’s doesn’t use the constant 12V pin, maybe the Kubota Jensen radios have a battery or something to keep station presets?
Anyway, things went great and installed the Kicker speakers too, really makes a difference.
