B2320 HST screaching/chattering noise
kenb2320
B2320, FEL, 48" Rotary Cutter, 1941 Farmall A, sickle bar mower, disc harrow
Apr 20, 2012
Simsbury, CT
I have a new B2320 with about 10 hours on it. The HST makes a screaching/ chattering noise when under a slight load (like going up a grade in medium) with the engine rpm's at 2200 rpm and higher. It does it in high also and forward and reverse. Does anyone else's do this and if so did you have it fixed?
Thanks,
Ken
hodge
Nov 19, 2010
2,907
459
Love, VA
I know this is an old thread but did you ever get this resolved?? We are looking at the B2320 now.
BUMP!!
Hydrostatic transmissions make noise- it's the nature of the beast. In high range, where a greater load is imposed, they are louder. It could be a problem, but in most cases, it is normal. In reference to the original post, I would need to hear it to tell whether it was typical or not. If you are looking at an HST tractor, make sure that you test drive it, and learn for yourself.
From the original poster's description, I would lay money that it is normal, and nothing was wrong with the tractor.
B7100
B7100,B7100 with Backhoe and FEL, Goldoni Quad 20
Feb 11, 2010
422
Wales
Can't quite remember what model or what the outcome was but Wasn't there once a thread where a noise was intensified through the Rop?
dave
