I have replaced the O-ring on the piston. It drops in a matter of minutes. No visible leaks.Over??? 5 minutes, 5 days?
What have you tried? Any visible leaks?
You really got to give us more to work with in order for us to help you out.I have replaced the O-ring on the piston. It drops in a matter of minutes. No visible leaks.
Solved the problem. The 0-ring was undersized. New O-ring solved the problem. Thank you.You really got to give us more to work with in order for us to help you out.
Which B7100 is it?
How did the cylinder walls look?
Does it pick weight?
Did you just replace the O-ring or did you do the backer ring?
How did the piston look?
Every detail is important or helpful.
Thanks for the follow up post.Solved the problem. The 0-ring was undersized. New O-ring solved the problem. Thank you.
