just died while driving
colorado dan
b7610
Apr 24, 2022
b7610, started nicely, driving slowly and just died. all dash lights on, turned key and no starter. checked safety switches under the seat, jumped them with a wire and still no response when i turned the key. Did power wash it 2 hours before and it started and drove great. What am I missing? are there other safety switches?
Mark_BX25D
Bx25D
Jul 19, 2020
1,753
1,275
I don't know the 7610, but multiple safety switches seem to be the norm. Seat, PTO, and maybe another.
2,965
I would check the fuses.
A safety interlock issue should not shut the tractor down once it is running.
2,551
On the BX it will - standing up while moving will shut it down quick like
Dieseldonato
Mar 15, 2022
728
439
Pa
My b7510 only shuts down for certain things normally it's a combination of the seat switch loosing contact and the pto or hydro pedal being moved. There is a few combinations for shut down, but I think it involves more then one switch in operation. It would be more likely you popped a fuse, but the starter and shut off solenoid are on different fuses. (I think). When I get home I can post the relevant pages of the manual so you can trouble shoot.
colorado dan
b7610
Apr 24, 2022
thanks for the advice and docs. i went through the check lists but found the solution by accident. When i bumped the lever for low/high speed getting onto the tractor it started up. A safety feature requires that the tractor be stopped to change the setting. New tractor for me and I need to learn all the features.
