torch
This might help:I have fruitlessly searched for an overall picture or diy post but haven't found one, so playing it by ear.
The valve I bought and that is linked above has a power beyond adapter included.
I am not sure on a total parts list, and what everything is called.
So does the low pressure return from the valve go to the adapter you mentioned into your fill port on the transmission?
B7100 Hydraulic block diverter (70060-00360 or 70070-00385)
Looking at charts like this: https://clearwaterhydraulics.com/hose-size-vs-gpm-ezp-24.html -06 is fine for 3 gpm, but getting iffy for 6 gpm. But the block is a local restriction -- in and of itself, it forms a small part of the entire system. The restriction in any elbows is several times...
www.orangetractortalks.com
The return can be via a 1/2" NPT nipple and tee in the fill port.
