Congrats on the new tractor! When you do the block heater you will need a 17mm hex bit socket the factory plug is tight probably on the order of 100 ftlbs. The block heater takes a 1 3/8" socket to install and even with thread sealer it needs to be very tight. I had to get mine to at least 80 ftlbs to stop it from dripping.
If you use Amazon the hex bit is oemtools 22843 $5.98 the socket is DeWalt demt19289b $4.00
Are the numbers for the tools
Some of the things I have added to my LX are in these posts....
				Hydraulic side link fabrication. This was more involved as I could not find a cylinder that was more or less a bolt on option at an affordable price. I ended up modifying a cylinder. As well as buying a spare side link to cut the mounts off of.  Total cost for this project was $271.60 plus my...
					www.orangetractortalks.com
				I just got a hydraulic top link from Spare parts Holland https://sparepartsholland.com/product/hydraulic-top-link-cat-1-1-with-locking-block-460-670-mm-with-2-x-hose/ It's also available on Amazon and on E-bay took about 4 days to arrive. For just a few buck more and without any risk of the fees...
If your doing much clearing in the woods there is not anything that works as good as a grapple. I have the EA Wicked 55 for mine but I had to wait 5 mounts for it to come....
