How are Military Tank Turrets Mounted?
3,252
Just a simple question.
I see some destroyed tanks sitting on the ground with their turrets on the ground beside them.
Is this a sign that turrets are basically just sitting there on bearings, expecting that nothing would cause them to be displaced and knocked off the tank base?
Just curious, having no knowledge...
3,252
They remove them to get out.
LOL...get real...LOL...take a look at the pictures...maybe superman could do that, but no real human beings....I was not talking about opening a hatch to get out. I was referring to the whole complete top of the tank being off to the side....
FTG-05
Jul 21, 2013
320
163
TN
Pretty much the same battleship turrets were installed. A bunch of turrets have fallen out of their mountings after being sunk, then turtling on their way down.
5,179
Those turrets were removed with a special turret removal device commonly known as a "Javelin"
I am told that it is very effective!
Reactions: 7 users
lynnmor
B2601-1
May 3, 2021
1,648
1,421
Red Lion
As for the bearings, yes they do have a very large diameter bearing so the gun can easily swivel. I worked at BMY nearly half a century ago and made some of those bearing races.
3,173
Decades ago, my dune group found a turret ring gear from what was probably an M3 Lee tank in Patton Valley in the Imperial Sand Dunes, after a huge windstorm. Went back the next day with enough people & gear to recover it, but someone had beaten us to it.
Biker1mike
Jan 11, 2022
1,174
1,274
Gallatin, NY USA
Russian tanks use an auto-loader which has the ammo in a ring just under and around the turret. When hit in the right place all of this ammo goes off at once and turns the 12 ton turret into a champagne cork. No one survives this.
US M1 uses a 19 kid with big biceps as the loader. Safer, but requires a much larger tank.
3,173
Like the Bismarck:
9,274
Tanks have to have the turrets bolted to the hull.
The turret itself is bolted to the upper ring. The upper and lower rings are kept together via a set of retainer screws.
Bmyers
May 27, 2019
3,482
4,391
Southern Illinois
You may find this video interesting, I know it is an American tank, but will give you some idea
woodsy
95 Kubota L3300DT W/FEL, 60" AgroTrend 3pt snow blower89 Arctic Cat 440 Panther
Apr 20, 2021
132
60
Maine
Spent some time in this Sheridan tank.. I'll take a tree to hide behind any day.
The main 152mm gun rounds were stored in the crew compartment also, ouch.
This thing would shake all over and front end would come up a foot when the main gun went off. Very big gun but not much range to it, 2000'.
lynnmor
B2601-1
May 3, 2021
1,648
1,421
Red Lion
My Dad took a nice stroll across Germany about 78 years ago, he said that the guys were instructed to walk behind the tanks for protection. It seemed to him that all the tanks were good for was to attract attention and enemy fire and a tree would be better.
5,504
2,211
Battleships are often mounted in the same fashion.
They have rollers, gearing, and such to help them turn, but there is nothing physically keeping them from falling out, just gravity and mass for the most part.
Bmyers
May 27, 2019
3,482
4,391
Southern Illinois
Very interesting video. I'm sure military experts/planners on all sides are going back to the drawing board and evaluating what was considered best practice.
Although the West seems to have placed more value on their soldiers than the East has traditionally done.
