I'm trying to put together a MX5400 using the Build My Kubota and I have a question regarding the Hydraulics/Hitch/Drawbar section under the Chose Options tab. Below are the choices you can make. Is the 4th choice different than a "Third Function Valve Kit"???? The reason I ask is that I want to buy a grapple for this unit and was told that I would need to have a Third Function Valve to run the grapple. If that #4 is not for a grapple what exactly is it used for?
Mounting Base with Valve Kits
1. None
2. 1ST POSITION LEVER KIT (MX6881 & L8303)
3. PLUS 2ND POSITION VALVE KIT (MX6881 & MX6882 & L8303)
4. PLUS 3RD POSITION VALVE KIT (MX6881 & MX6882 & MX6883 & L8303(2))
And if you chose #4 it adds the following in the list of options to you tractor
1 1ST POS LEVER KIT MX5400/MX6000 ROPS
(MX6881)
1 2ND POS LEVER KIT MX5400/MX6000 ROPS
(MX6882)
1 3RD POS LEVER KIT MX5400/MX6000 ROPS
(MX6883)
2 DOUBLE ACTING VALVE
(L8303)
Thanks for the help!!
1. None
(MX6881)
(MX6882)
(MX6883)
(L8303)
