B7100HST cooling question
EddyG
7100 HST
May 2, 2012
Kansas
I am new here, and have tried to research this in the search feature but haven't found an answer to my question.
I am a mechanic but not on Kubotas.
My tractor is overheating. Blowing steam from the overflow. I figured the thermostate was not opening.
Does this model have a thermostate? waterpump? I have read that some do not.
In order for me to fix this I am trying to understand the system. where I think the thermostate is may not be. and before I tear into this I am hopeing on some education from here.
Thanks.
steve
B7100HST, B5001DT/B5100DT, JD-111H, Chevy K2500 DuraMax, CJ-5, CJ-7, TJ jeeps
Feb 17, 2009
51
Henniker. NH, USA
Eddy
There is no thermostat or water pump. The systen is a thermo-siphon where the hot water from the block rises into the radiator and is cooled. The heavier cool water sinks to the bottom of the radiator and back into the lower side of the block. Flush your system out and replace the anti-freeze. Make sure the upper hose into the radiator is full with A/F or the siphon won't work. Check that the grill and front of the rad are clean. Should work like a charm. No moving parts!
Steve
EddyG
7100 HST
May 2, 2012
Kansas
Thanks Steve.
I will search on flushing the system and making sure the coolant is totally full. And try that.
I'll be back with more questions if I can't get it working...:)
kubotasam
Apr 26, 2010
1,212
137
Alfred Maine
I agree 100%. When my B7100 starts running hot I need to blow out the radiator with compressed air.
hodge
Nov 19, 2010
2,959
531
Love, VA
Yep. You've gotta keep that radiator clean.
Rob
B6000DT / B7100DP /B8200DT/L225/Globe PTO Chipper/Lewis Backhoe/huxley TR66
Nov 22, 2009
679
11
Leafy England....
hi guys, i do have a query on this guys.
I have a mid production run B7100d and a late run B7100hst-d and both have water pumps.
They both have the side mounted dynamo's unlike you guys that have the top mounted dynamo with the fan on it, whereas mine has the fan on the waterpump.
I have been looking at the kubota workshop manual for the 70mm series engines which does tally up with mine.
By anychance is the D-750A engine fitted to yours only a US version , mine over here it appears to be the D-750B unit as per workshop manual. If so, it may account for why i was having issues with hose diameters between radiators, the larger hoses on the non-pumped engines and smaller ones on the pumped units.
both my 7100's use the smaller dia hoses and both sets of hoses are indentical eventhough there is about a 6 year gap between them.
whereas the rad i got from a late B6100 uses the larger hoses, but it also has the dynamo fitted to the top water outlet on the head and not the side fitted dynamo as on the 7100's.
attached pics of the D750B setup, same as my mine, last pic is also b7100, but same as the late B6100 i took the radiator from with the larger hoses etc.
I reckon its a D750A and a D650A
can anyone clarify things,or am i just going on about a load of rubbish.......
rob
Rob
Nov 22, 2009
679
11
Leafy England....
just been out in the workshop and had a look at the 2 B7100's , they both have water pumps and thermostats.
you guys must have way different versions over there.....
3,499
I was just thinking the same thing..... I've never seen one with a water pump or a thermostat.
Rob
Nov 22, 2009
679
11
Leafy England....
It certainly makes you think, i fully understand that you get slight variations in model spec from country to country etc, but there is a major engine variaition going on here.
Its cant be a case of egines being changed through their production life because mine are a late 70 and mid eighties and both have the same design engine, the D750-B.
maybe service dept vic can enlighten us.....
rob
Stumpy
L175
Dec 1, 2011
848
NE Ohio
I can't remember who but someone with an L175 noted they have a water pump while I do not. The pump isn't listed in the parts books either. I really cannot fathom why they never changed the parts books. I went and looked at all three parts books on kubotabooks.com for the b7100 and none of them show a water pump either. They do show a funky looking alternator behind the fan though.
Rob
Nov 22, 2009
679
11
Leafy England....
yep, i can recall seeing similar also.
I seem to have aquired lots of B6000/b6100/7100 etc manuals and workshop manuals over a short period, probably too much to be honest.
In all of the B7100 paperwork , none show the waterpump and thermostat, they dont list the engine version as the D750-b either.
The only manual that actually shows the correct engine and electrics spec as far as my model is concerned is the Kubota wsm.
page attached.
Rob
Nov 22, 2009
679
11
Leafy England....
well i appear to have resolved the issue of water pump or no pump,
Its a Uk thing.
I spoke with Kubota UK today and they explained the possible confusion etc, they confirmed that the uk spec 7100's were suppied directly with the 750-b unit which has the water pump.thermostat and side mounted Alternator (not dynamo).
something to do with needing more power hence the fitting of an alternator over the normal dynamo.
This also clears up the issue with wiring diagrams also, the 7100 in the uk have the revised wiring loom which does not appear in the normal 6100/7100 owners/users manuals etc, but is in the kubota 70 series engines workshop manual.
You see, there are a few benafits of living on this little island, not many, but a few.
rob
debilbao
Spain
Hi
I'm interested on add a water pump to my b7001.
I'm not sure if possible, and looking pictures i think there is needed something between pump and piece numbered 1.
Could anyone post part list with kubota references to get more info?
Pictures from a d750 with pump on it, would help to.
Thanks in advance.
dotty
2008 Kubota L3400D 4wd, 1992 Kubota B7100 HST, 1977 M-F 230 Diesel, 1949 Ford 8N
Aug 10, 2013
14
Indiana
Eddy
Steve
I just installed a Davies, Craig electric water pump with controller on my B7100HST. It took a couple of afternoons and several trips to Autozone for hose, etc. So far it works well, no overheating even after lugging engine with box grader. $400 online from Pegasus Auto Racing Supplies. Well thought out kit.
kubotasam
Apr 26, 2010
1,212
137
Alfred Maine
Sure would like to see some pictures and if you could, post the part number of the water pump and controller.
Thanks-- sounds like a great mod.
kubotasam
Apr 26, 2010
1,212
137
Alfred Maine
Interesting set up. I never thought of putting one in the lower radiator hose.
Thanks for posting the pictures.
3,039
Remote water pump info
SO is that a variable speed pump?
Reason I ask - looking at all those wires I bet it senses heat and when to cut the pump on?
otherwise a typical pump would circulate water all the time - and the engine would take a good while to get to operating temperature!
Looks like a nice setup - other than the cost!:D;)
dotty
Aug 10, 2013
14
Indiana
Yes, it is variable speed. When engine is cold the pumps runs for 10 seconds off 30 seconds at 6 volts. At 36 F below setpoint pump runs 10 seconds off 10 seconds at 6 volts. At 9 F below setpoint pump runs continuously at varying speeds to control temperature to setpoint.
The magic of microprocessors. I bought the EWP80, the photo in the post is the EWP115.
