Idling
Vlach7
L47 305DT JD500C
Dec 16, 2021
435
317
Frazier Park Ca
Idling, going to be picking up rocks off the property where it might sit for 5 minutes, at what point is it better for my Teir 4 tractor to just shut down and restart?
Biker1mike
Jan 11, 2022
1,174
1,274
Gallatin, NY USA
Most diesels will run without a battery but will not start without one. I shut mine down to do some work. When I went to restart the tractor was dead. The battery ground cable finally broke from unseen corrosion. Long walk back to get new cable and repair.
I have never had an issue letting idle for long periods ever since.
The price of fuel may the bigger issue right now.
mcfarmall
Kubota M5660SUHD, Farmall C
Sep 11, 2013
1,444
1,740
Kalamazoo, MI
The general consensus on this and other forums is minimum 1850 rpm, maximum wot for best overall DPF health. I run mine wherever I want and it regens whenever it wants.
loggin
MX4700
Sep 4, 2021
111
39
canada
Carbon build up and/or wet stacking can occur if a diesel is idling for too long. Diesels are built for operating under load and if that does not happen often enough then the aforementioned can happen.
Not necessarily saying it happens in 5 minutes but over time it will. Depends on what you are doing after the 5 minutes. Are ploughing or are you just running light load and dumping the rocks you just gathered?
10,063
If it's not a regen engine then leave it idle, if it is don't!
Vlach7
L47 305DT JD500C
Dec 16, 2021
435
317
Frazier Park Ca
Yes, it is a regen engine, and yes, I just go and dump the rocks, I will just shut her down, it won't be long between regens if I leave her idling. Thanks guys.
Dennis.D
L6060, Erskine hydraulic snow blower, back hoe
Feb 16, 2018
146
59
Central, ME,USA
If I have a project that requires a lot of in and out of the cab I will just leave the engine @ 2000ish rpm's. Same when I'm using the winch. With the older non tier4 I would leave the engine @ 1500rpm's. I never left any tractor at dead idle for long periods.
sheepfarmer
Nov 14, 2014
4,438
677
MidMichigan
The newer tier IV engines are easier to start, less drain on battery, and yes idling will cause frequent regens. If you are off the tractor for more than 3 or 4 minutes, shut it off.
Vlach7
L47 305DT JD500C
Dec 16, 2021
435
317
Frazier Park Ca
Thanks all, Yes,
every time I moved took at least 20 minutes so I shut her down and yes starts very easy.
3,820
5 mins….?? Let ‘er idle. More than 10 mins..?? Shut ‘er down. (but I have the luxury of a non-emissions pre-Tier engine.)
cthomas
LX2610 HSDC
Jan 1, 2017
848
563
La Farge Wi
Shut it off, as the DPF needs to be hot to operate properly. I have researched this issue a lot before buying my LX2610 as I wanted a little more horsepower, but this will be my last tractor(maybe) and did not want this emission issues down the road. Researched this and even my brother bought a L3240 pre emission. Looked at a few B3350's knowing the emission issues(delete kit would have been installed).
