I see post where folks spend up to $25 dollars to purchase a cup holder for their tractor. I read them because I find them somewhat entertaining and it reminds me to be thankful I took a welding class years ago to not be in that boat!
My L4240 has a cup holder "if that's what you want to call it" behind the seat on the left side, and it's about 2 1/2" deep. Can't reach back very easily with either hand to reach it. Here's my solution.
Had a piece of thin wall tubing like used for old time gas lights folks had in their front yard and cut off about 3 1/2". Had a assortment of flat washers, found one that just fit inside the tubing and welded it there. Had a piece of 1" x 1/8 bar, cut if off the same length as the tubing, drilled two 1/8" holes near the top and bottom, and welded it vertical on one side of the tubing. Used tapered head SS bolts to attach two neodymium magnets rated at 27# each.
A can/or bottled drink fits in a koozie and the whole thing rides where I can see and reach it. I put it on the loader tower and while grappling for two hours it didn't move.
Patent pending.
Patent pending.
