Missing bolt?
Norman
LX2610HSD;LA535;LP 60" grapple; WC68 chipper; GB60 SW cutter
Sep 30, 2021
84
97
Georgia, USA
Testing out the new 535 loader in the woods and the bucket level indicator fell off. I assume a bolt is supposed to keep it connected? See in the pic the part I am referring to.
2,551
not sure if it is a threaded bolt or a bolt with a cotter pin - either way that needs to "float" against the bracket.
Elliott in GA
Mar 10, 2021
743
725
North Georgia
My LX2610 SU came with the indicator (was in stock at the dealer), and it fell off within the first 20 hrs. I bought the replacement parts (a C clip, bolt and nut hold it on at the bottom - if I remember correctly, you adjust the bolt within the rack, and the rod attaches to the end of the bolt with the C clip). I put it back on, and then I looked at it for a couple of minutes. I took it off, and I put it in storage.
I realized that I never looked at the thing; I always looked at the top flat edge of the bucket (very visible with the LX). It also seemed to be a bit vulnerable. I believe I knocked mine off scooping gravel from a large pile. So far, I have scooped/moved over 70 tons of gravel, and I have not missed it when digging, grappling or other FEL activities.
Norman
Sep 30, 2021
84
97
Georgia, USA
Very helpful info, thank you. I’ll have to learn how to search parts now, looks to be very handy. I’m used to that for my vehicles, but still relatively new to tractors.
Nicksacco
Sep 15, 2021
679
386
Bahama, NC
Here is another site for parts.
I've used them a lot and they are very good for delivery and inventory.
Hopefully you have manuals for your tractor and attachments too.
Lots of great info here - maintenance is Number 1!
Oils, greases, filters and such are keys to long life.
Goodluck to you!
Joisey
Kubota L47 TLB
May 31, 2015
191
124
Wild, Wonderful West Virginia
Though it wouldn't be "correct", I'll bet a common 3/8 inch carriage bolt, flat washer and self locking nut would do exactly the same thing for about a quarter of the cost, and not fall off.
Norman
Sep 30, 2021
84
97
Georgia, USA
It did work. Found what I needed in my bolt bins.
Joisey
Kubota L47 TLB
May 31, 2015
191
124
You can get a higher grade carriage bolt IF you wanted one. I believe that they are available in grade 5 and grade 8. Regular carriage bolts are grade 2, which is sufficient for what you are using it for.
After I posted, I thought that perhaps a carriage bolt thru the slotted piece, then a flat washer, your rod, another flat washer followed by a locking nut would give you a smoother slide along the slot.
I'm glad it worked out for you.
